2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem building example application on windows-x64
To: Michael Davidsaver <[email protected]>, 'Andrew Johnson' <[email protected]>, "'[email protected]'" <[email protected]>
Date: Fri, 29 Dec 2017 14:06:21 +0000
I have tested the fixes.
I did the following in module/pvData and modules/pvAccess
git checkout master
git pull
Rebuilt base for windows-x64 and windows-x64-static.
Rebuilt example application for both ARCHs.
It appears to fix both problems:
- windows-x64 no longer hangs with WINSOCK errors when exiting.
- windows-x64-static no longer crashes on startup.
Sent: Thursday, December 28, 2017 12:23 PM
To: Mark Rivers; 'Andrew Johnson'; '[email protected]'
I have committed possible fixes for the first two issues.
On 12/28/2017 09:37 AM, Michael Davidsaver wrote:
> So much for that.  I manged to miss this issue.  Time to open some tickets I think.
> So far I count four distinct symptoms, and the test failures.
> What I see so far:
> 1. Global ctor ordering issues needs to be opened against pvDataCPP and pvAccessCPP
>    (any probably others).
https://github.com/epics-base/pvDataCPP/issues/49
w/ candidate fix
> 2. The osiSockAttach() issue against pvAccessCPP.
https://github.com/epics-base/pvAccessCPP/issues/81
w/ candidate fix
> 3. The Com.res failure against Base (on launchpad)
https://bugs.launchpad.net/bugs/1740408
> 4. The timestamp issue w/ genVersionHeader.pl against Base
tbd.
Re: Problem building example application on windows-x64 Michael Davidsaver
RE: Problem building example application on windows-x64 Mark Rivers
Re: Problem building example application on windows-x64 Andrew Johnson
Re: Problem building example application on windows-x64 Mark Rivers
Prev: Re: Problem building example application on windows-x64 Michael Davidsaver
Next: Re: Problem building example application on windows-x64 Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 29 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
