Sent: Wednesday, December 27, 2017 3:15 PM
To: 'Andrew Johnson'; [email protected]
Subject: RE: Problem building example application on windows-x64
OK, that patch let me get the example application to compile.
However, there are problems when running it. The behavior I see is different on windows-x64 and windows-x64-static.
- On windows-x64 the IOC application runs OK but when I try to exit the application I get the error I reported in my first message today, i.e. epicsSocketDestroy errors. ^C will not kill the IOC application, I need to use the Task Manager.
This is a serious problem, and as I said earlier it affects other IOCs such as simDetector.
J:\epics\devel\example\iocBoot\ioctest>..\..\bin\windows-x64\test.exe st.cmd
#!../../bin/windows-x64-static/test
< envPaths
epicsEnvSet("IOC","ioctest")
epicsEnvSet("TOP","J:/epics/devel/example")
epicsEnvSet("EPICS_BASE","H:/epics-devel/base-7.0.1")
cd "J:/epics/devel/example"
dbLoadDatabase "dbd/test.dbd"
test_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadTemplate "db/user.substitutions"
dbLoadRecords "db/testVersion.db", "user=rivers"
dbLoadRecords "db/dbSubExample.db", "user=rivers"
#var mySubDebug 1
#traceIocInit
cd "J:/epics/devel/example/iocBoot/ioctest"
iocInit
Starting iocInit
## EPICS R7.0.1.1
## EPICS Base built Dec 16 2017
2017-12-27T14:52:54.595 No broadcast addresses found or specified - empty address list!
## Start any sequence programs
#seq sncExample, "user=rivers"
epics>
epics>
epics>
epics>
epics> exit
epicsSocketDestroy: failed to close a socket because "WINSOCK Error 10093"
2017-12-27T14:53:16.250 Receive thread for UDP socket 0.0.0.0:0 has not exited.
2017-12-27T14:53:21.296 Receive thread for UDP socket 164.54.160.31:5076 has not exited.
2017-12-27T14:53:26.333 Receive thread for UDP socket 0.0.0.0:5076 has not exited.
On windows-x64-static the IOC crashes immediately, without even starting to execute the st.cmd file:
J:\epics\devel\example>make -sj clean uninstall
devXxxSoft.c
xxxRecord.c
testHello.c
dbSubExample.c
devtestVersion.c
initTrace.c
testMain.cpp
test_registerRecordDeviceDriver.cpp
../devtestVersion.c(27) : warning C4267: '=' : conversion from 'size_t' to 'epicsUInt32', possible loss of data
../xxxRecord.c(211) : warning C4244: '=' : conversion from 'epicsFloat64' to 'float', possible loss of data
Appending initTrace.obj
Appending testHello.obj
Appending devtestVersion.obj
Appending dbSubExample.obj
Appending devXxxSoft.obj
Appending xxxRecord.obj
J:\epics\devel\example>cd iocBoot\ioctest
J:\epics\devel\example\iocBoot\ioctest>..\..\bin\windows-x64-static\test.exe st.cmd
At that point Windows pops up a dialog box telling me that test.exe has crashed. Opening the Visual Studio debugger tells me that it is an access violation on address 0.
Is there a test in EPICS base that instantiates the example IOC?
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Andrew Johnson
> Sent: Wednesday, December 27, 2017 1:04 PM
> To: [email protected]
> Subject: Re: Problem building example application on windows-x64
> Hi Mark,
> On 12/27/2017 12:05 PM, Mark Rivers wrote:
> > I just did this again, but running makeBaseApp.pl with Windows rather
> > than Linux. I get the same problem. It looks like the problem is that
> > testVersion.h is changing because the timestamp is incrementing by 1
> > second between the time it is created and checked?
> I agree; it seems to be a problem with the genVersionHeader.pl script
> that Michael added in 3.16.1 and the dependency rules. This is the
> relevant part of your build log:
> > perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/genVersionHeader.pl
> > -t ../../.. -N testVERSION -V "" ../O.Common/testVersion.h
> > Updating VCS header ../O.Common/testVersion.h
> > testVERSION = "2017-12-27T11:39:33"
> > perl -CSD H:/epics-devel/base-7.0.1/bin/windows-x64/mkmf.pl -m
> > devtestVersion.d -I. -I../O.Common -I. -I. -I..
> > -I../../../include/compiler/msvc -I../../../include/os/WIN32
> > -I../../../include -IH:/epics-devel/base-7.0.1/include/compiler/msvc
> > -IH:/epics-devel/base-7.0.1/include/os/WIN32
> > -IH:/epics-devel/base-7.0.1/include devtestVersion.obj
> > ../devtestVersion.c
> > testVERSION = "2017-12-27T11:39:34"
> > ../devtestVersion.c
> > testVERSION = "2017-12-27T11:39:35"
> whereas on Linux I get:
> > perl -CSD /home/phoebus/ANJ/epics/base/7.0/bin/linux-x86_64/genVersionHeader.pl
> > testVERSION = "2017-12-27T12:08:23-0600"
> > /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -
> DUSE_TYPED_RSET
> > -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64
> > -Wpointer-arith -fvisibility=hidden -fPIC -I. -I../O.Common -I. -I. -I..
> > -I../../../include/compiler/gcc -I../../../include/os/Linux
> -I../../../include
> > -I/home/phoebus/ANJ/epics/base/7.0/include/compiler/gcc
> > -I/home/phoebus/ANJ/epics/base/7.0/include/os/Linux
> > -I/home/phoebus/ANJ/epics/base/7.0/include -MM -MF devtestVersion.d
> > ../devtestVersion.c
> > Keeping VCS header ../O.Common/testVersion.h
> There seems to be a mismatch between the assumptions that script makes
> about file-system modification times and how GNUmake works on Windows.
> The old DOS FAT file-system had a time-stamp granularity of 2 seconds
> and that has resulted in some workarounds being added to GNUmake on
> Windows, e.g. see
http://www.delorie.com/djgpp/v2faq/faq22_18.html or
> there may be a delay added at the end of the phase-1 run before GNUmake
> re-reads the Makefiles — that might explain what's happening here.
> Michael: How about we drop the seconds field completely from the build
> date/time-stamp? That should prevent this kind of problem from
> recurring. It would still trigger a re-creation of the header whenever
> there is a roll-over, but that should only happen once, not continuously
> like Mark is seeing.
> Mark: If you want to try out that fix, edit
> base-7.0/src/tools/genVersionHeader.pl and make this change:
> > diff --git a/src/tools/genVersionHeader.pl b/src/tools/genVersionHeader.pl
> > index 5851ea8..8e50fec 100644
> > --- a/src/tools/genVersionHeader.pl
> > +++ b/src/tools/genVersionHeader.pl
> > @@ -19,7 +19,7 @@ use POSIX qw(strftime);
> > use strict;
> > # RFC 8601 date+time w/ zone (eg "2014-08-29T09:42:47-0700")
> > -my $tfmt = '%Y-%m-%dT%H:%M:%S';
> > +my $tfmt = '%Y-%m-%dT%H:%M';
> > $tfmt .= '%z' unless $^O eq 'MSWin32'; # %z returns zone name on Windows
> > my $now = strftime($tfmt, localtime);
> - Andrew
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
