2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: makeBaseApp example / QSRV
To: Ralph Lange <[email protected]>, EPICS Core Talk <[email protected]>
Date: Thu, 14 Dec 2017 10:11:38 -0600
On 12/14/2017 09:16 AM, Ralph Lange wrote:
> Another follow-up:
> I have added conditional linking of QSRV (if it is available) to the makeBaseApp exampleApp template.
> I also tried adding the circle.db library from the QSRV demos, but I can't access the groups through PVA. (Single channels of the records from the circle.db work.)
> @Michael: what can I do to debug this? (pvasr looks normal, remote pvlist yields: "not implemented".)
oops, Timo is correct.  ioccircle and ioccircle2 are out of date.  Also, iocpvalink is broken.
The working ones are iocwfdemo and iocimagedemo.
I would just remove them for the release.  I can re-add after correcting them.
makeBaseApp example / QSRV Ralph Lange
Prev: Re: makeBaseApp example / QSRV Timo Korhonen
Next: Re: makeBaseApp example / QSRV Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: makeBaseApp example / QSRV Ralph Lange
Next: 7.0.1 Final Andrew Johnson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
