2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: makeBaseApp example / QSRV
To: Ralph Lange <[email protected]>, EPICS Core Talk <[email protected]>
Date: Thu, 14 Dec 2017 15:55:27 +0000
From: <[email protected]> on behalf of Ralph Lange <[email protected]>
Date: Thursday 14 December 2017 at 16:16
To: EPICS Core Talk <[email protected]>
Subject: makeBaseApp example / QSRV
Another follow-up:
I have added conditional linking of QSRV (if it is available) to the makeBaseApp exampleApp template.
Thanks, this is nice.
I also tried adding the circle.db library from the QSRV demos, but I can't access the groups through PVA. (Single channels of the records from the circle.db work.)
@Michael: what can I do to debug this? (pvasr looks normal, remote pvlist yields: "not implemented".)
The info tags to create the groups in the circle.db may not be the final ones. I had the same issue. The image.db example (I hope this is the right name) has info tags that work.
pvlist did not work for me either, I think it is just not implemented in qsrv yet. Would be cool to have at some point though, as it used to work with the old pvaSrv.
Timo
Cheers,
~Ralph
Re: makeBaseApp example / QSRV Ralph Lange
Prev: Re: 7.0.1-rc1 Torsten Bögershausen
Next: Re: makeBaseApp example / QSRV Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: makeBaseApp example / QSRV Ralph Lange
Next: Re: makeBaseApp example / QSRV Ralph Lange
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
