Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: EPICS 7.0.1-pre1 (typeCast.h)
To: Michael Davidsaver <mdavidsaver@gmail.com>, <core-talk@aps.anl.gov>
Date: Thu, 23 Nov 2017 08:50:49 +0100
On 22.11.2017 16:51, Michael Davidsaver wrote:
On 11/22/2017 06:28 AM, Dirk Zimoch wrote:
The vxWorks 6.6 and 6.7 builds failed here:
../../src/misc/pv/typeCast.h: In function
'void<unnamed>::castVTyped(size_t, void*, const void*) [with TO = long
long unsigned int, FROM = double]':
../../src/misc/pv/typeCast.h:168: sorry, unimplemented: inlining failed
in call to 'TO epics::pvData::castUnsafe(const FROM&) [with TO = long
long unsigned int, FROM = double]': function not considered for inlining
../../src/misc/typeCast.cpp:37: sorry, unimplemented: called from here
Which GCC version is involved here?  It seems like the logic controlling
FORCE_INLINE in templateMeta.h needs to be adjusted.
https://github.com/epics-base/pvDataCPP/blob/master/src/misc/pv/templateMeta.h#L13
This is the gcc that comes with vxWorks:
vxWorks 6.6:
gcc version 4.1.2 (Wind River VxWorks G++ 4.1-82)
vxWorks 6.7:
gcc version 4.1.2 (Wind River VxWorks G++ DWARF-EH 4.1-131)
It gets "__attribute__((always_inline)) inline" and understands it. It just does not like inlining that particular function, but does not say why.
Here is the pre-processed code:
# 167 "../../src/misc/pv/typeCast.h"
template<typename TO, typename FROM>
static __attribute__((always_inline)) inline TO castUnsafe(const FROM& from)
    return detail::cast_helper<TO,FROM>::op(from);
__attribute__ ((visibility("default"))) extern void castUnsafeV(size_t count, ScalarType to, void *dest, ScalarType from, const void *src);
It is called from here:
namespace {
static void noconvert(size_t, void*, const void*)
    throw std::runtime_error("castUnsafeV: Conversion not supported");
static void castVTyped(size_t count, void *draw, const void *sraw)
    TO *dest=(TO*)draw;
    const FROM *src=(FROM*)sraw;
    const FROM *last = src+count;
    try {
        while (src != last) {
          *dest = castUnsafe<TO,FROM>(*src);
          ++dest; ++src;
    } catch (std::exception& ex) {
Re: EPICS 7.0.1-pre1 (typeCast.h) Dirk Zimoch
EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Dirk Zimoch
Re: EPICS 7.0.1-pre1 (typeCast.h) Michael Davidsaver
Prev: Re: EPICS 7.0.1-pre1 Dirk Zimoch
Next: Re: EPICS 7.0.1-pre1 (typeCast.h) Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: EPICS 7.0.1-pre1 (typeCast.h) Michael Davidsaver
ANJ, 23 Nov 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
