Hi everyone,
I have built EPICS 7.0.1-pre1 today for several vxWorks and embedded
Linux target architectures. Unfortunately I have a number of build fails
for architectures that used to work with 3.16.1.
Success:
Red Hat Enterprise Linux 7 64 bit with gcc and clang (host)
Scientific Linux 6 32 and 64 bit (cross from RHEL7)
ELDK 5.1 ppc 4xx and 5.2 ppc e500v2 32 bit
yocto 2.0 ppc e6500 64 bit
yocto 2.1 arm v8 64 bit (aarch64, Zynq)
Fail:
All vxWorks builds (6.2, 6.3, 6.6, 6.7 ppc603 and ppc604)
Montavista Linux 4.0 arm v5 (xscale, Moxa)
some unknown embedded Linux arm v6 (Moxa)
ELDK 4.2 ppc 4xx 32 bit
The vxWorks 6.2 and 6.3 builds failed here:
In file included from
/usr/local/epics/base-7.0.1/include/os/vxWorks/boost/smart_ptr/detail/spinlock_pool.hpp:25,
from
/usr/local/epics/base-7.0.1/include/os/vxWorks/boost/smart_ptr/shared_ptr.hpp:38,
from
/usr/local/epics/base-7.0.1/include/os/vxWorks/boost/shared_ptr.hpp:17,
from
/usr/local/epics/base-7.0.1/include/os/vxWorks/boost/tr1/memory.hpp:56,
from ../../src/misc/pv/sharedPtr.h:133,
from ../pv/pvType.h:41,
from ../pv/pvIntrospect.h:17,
from ../pv/pvData.h:24,
from ../../src/json/print.cpp:11:
/usr/local/epics/base-7.0.1/include/os/vxWorks/boost/smart_ptr/detail/spinlock.hpp:47:52:
boost/smart_ptr/detail/spinlock_pt.hpp: No such file or directory
The vxWorks 6.6 and 6.7 builds failed here:
../../src/misc/pv/typeCast.h: In function
'void<unnamed>::castVTyped(size_t, void*, const void*) [with TO = long
long unsigned int, FROM = double]':
../../src/misc/pv/typeCast.h:168: sorry, unimplemented: inlining failed
in call to 'TO epics::pvData::castUnsafe(const FROM&) [with TO = long
long unsigned int, FROM = double]': function not considered for inlining
../../src/misc/typeCast.cpp:37: sorry, unimplemented: called from here
Two embedded Linux cross builds for Moxa serial servers fail here:
perl -CSD ../../src/env/bldEnvData.pl -t moxa42-armv6l \
-c gcc -s /usr/local/epics/base-7.0.1/configure
Usage: bldEnvData.pl [options] configure
-h Help: Print this message
-q Quiet: Only print errors
-o file Output filename, default is envData.c
-t arch Target architecture $(T_A) name
-s os Operating system $(OS_CLASS)
-c comp Compiler class $(CMPLR_CLASS)
make[4]: *** No rule to make target `../O.Common/osiFileName.h', needed
by `inc'. Stop.
make[4]: Leaving directory
`/afs/psi.ch/group/8431/dirk/git/BASE/base-7.0.1-pre1/modules/libcom/src/O.moxa42-armv6l'
ELDK 4.2 ppc 4xx cross build fails here:
../pvif.h: In constructor 'PDBSinglePut::PDBSinglePut(const
std::tr1::shared_ptr<PDBSingleChannel>&, const
std::tr1::shared_ptr<epics::pvAccess::ChannelPutRequester>&, const
std::tr1::shared_ptr<epics::pvData::PVStructure>&)':
../pvif.h:291: error: 'FieldName::FieldName(const FieldName&)' is private
../pdbsingle.cpp:300: error: within this context
../pvif.h: In member function 'virtual void PDBSinglePut::put(const
std::tr1::shared_ptr<epics::pvData::PVStructure>&, const
std::tr1::shared_ptr<epics::pvData::BitSet>&)':
../pdbsingle.cpp:364: error: within this context
../pdbsingle.cpp:386: error: within this context
make[4]: *** [pdbsingle.o] Error 1
There are a a number of warnings (different for different target archs).
Should we do something about them?
epicsTempFile.o: In function `epicsTempName':
epicsTempFile.cpp:(.text+0x2a): warning: the use of `tmpnam' is
dangerous, better use `mkstemp'
In file included from ../../src/osi/os/Linux/osdFindAddr.c:10:
../../src/osi/os/posix/osdElfFindAddr.c: In function ‘epicsFindAddr’:
../../src/osi/os/posix/osdElfFindAddr.c:642: warning: cast to pointer
from integer of different size
../../src/osi/os/vxWorks/osdFindSymbol.c: In function `epicsLoadLibrary':
../../src/osi/os/vxWorks/osdFindSymbol.c:48: warning: implicit
declaration of function `close'
../../src/error/errlog.c: In function `errlogPrintf':
../../src/error/errlog.c:110: warning: 'nchar' might be used
uninitialized in this function
../../src/osi/os/vxWorks/vxComLibrary.c: In function 'vxComLibrary':
../../src/osi/os/vxWorks/vxComLibrary.c:26: warning:
'symFindByNameEPICS' is deprecated (declared at
../../src/osi/os/vxWorks/epicsDynLink.h:30)
../../src/osi/os/vxWorks/veclist.c: In function 'veclist':
../../src/osi/os/vxWorks/veclist.c:76: warning: 'symFindByValue' is
/afs/psi.ch/project/vxworks/VxWorks6.6/vxworks-6.6/target/h/symLib.h:119)
../tcpiiu.cpp: In member function `bool tcpiiu::processIncoming(const
epicsTime&, callbackManager&)':
../tcpiiu.cpp:1212: warning: `arrayElementCount newsize' might be used
In file included from ../access.cpp:45:0:
../oldAccess.h:406:10: warning: ‘template<class> class std::auto_ptr’ is
deprecated [-Wdeprecated-declarations]
std::auto_ptr < CallbackGuard > pCallbackGuard;
/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux/usr/include/c++/6.2.1/memory:81:0,
from ../oldAccess.h:29,
/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux/usr/include/c++/6.2.1/bits/unique_ptr.h:49:28:
note: declared here
../Cap5.xs: In function ‘CA_put’:
../Cap5.xs:638:16: warning: ‘p.dbr’ may be used uninitialized in this
function [-Wmaybe-uninitialized]
status = ca_array_put(type, num_values, pch->chan, p.dbr);
../../../src/ioc/db/dbChannelIO.cpp:152:13: warning: comparison of
constant -1 with expression of type 'unsigned short' is always true
[-Wtautological-constant-out-of-range-compare]
dbf_type_to_text ( dbChannelExportCAType ( this->dbch ) ),
/usr/local/epics/base-7.0.1/include/db_access.h:687:16: note: expanded
from macro 'dbf_type_to_text'
( ((type) >= -1 && (type) < dbf_text_dim-2) ? \
In file included from ../../../src/ioc/db/dbContext.cpp:29:0:
../../../src/ioc/db/dbCAC.h:197:10: warning: ‘template<class> class
std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
std::auto_ptr < cacContext > pNetContext;
from ../../../src/ioc/db/dbCAC.h:29,
note: declared here
template<typename> class auto_ptr;
../../../src/ioc/db/dbChannelIO.cpp: In member function 'virtual void
dbChannelIO::show(epicsGuard<epicsMutex>&, unsigned int) const':
../../../src/ioc/db/dbChannelIO.cpp:152: warning: comparison is always
true due to limited range of data type
../../../src/ioc/dbStatic/dbStaticLib.c: In function 'dbGetStringNum':
../../../src/ioc/dbStatic/dbStaticLib.c:2126: warning: comparison is
always false due to limited range of data type
../../../src/ioc/dbStatic/dbStaticLib.c:2146: warning: comparison is
../../../src/ioc/rsrv/camessage.c: In function 'read_action':
../../../src/ioc/rsrv/camessage.c:630: warning: comparison is always
../../../src/ioc/rsrv/camessage.c: In function 'read_notify_action':
../../../src/ioc/rsrv/camessage.c:721: warning: comparison is always
../../../src/ioc/rsrv/camessage.c: In function 'event_add_action':
../../../src/ioc/rsrv/camessage.c:1787: warning: comparison is always
../../../src/std/link/lnkCalc.c: In function `lnkCalc_string':
../../../src/std/link/lnkCalc.c:184: warning: subscript has type `char'
../../src/misc/reftrack.cpp:268:15: warning: unused variable 'now'
[-Wunused-variable]
epicsTime now(epicsTime::getCurrent());
../../src/factory/FieldCreateFactory.cpp: In member function
'epics::pvData::int32 epics::pvData::Union::guess(epics::pvData::Type,
epics::pvData::ScalarType) const':
../../src/factory/FieldCreateFactory.cpp:625: warning: 'type' may be
used uninitialized in this function
../../src/misc/pv/reftrack.h:108: warning: 'class epics::RefMonitor' has
virtual functions but non-virtual destructor
../../testApp/misc/testThread.cpp:26:
/usr/local/epics/base-7.0.1/include/pv/executor.h:37: warning: ‘Command’
/usr/local/epics/base-7.0.1/include/pv/executor.h:35)
/usr/local/epics/base-7.0.1/include/pv/executor.h:59: warning:
‘Executor’ is deprecated (declared at
/usr/local/epics/base-7.0.1/include/pv/executor.h:57)
In file included from ../../testApp/misc/testThread.cpp:27:
/usr/local/epics/base-7.0.1/include/pv/timeFunction.h:31: warning:
‘TimeFunctionRequester’ is deprecated (declared at
/usr/local/epics/base-7.0.1/include/pv/timeFunction.h:29)
/usr/local/epics/base-7.0.1/include/pv/timeFunction.h:50: warning:
‘TimeFunction’ is deprecated (declared at
/usr/local/epics/base-7.0.1/include/pv/timeFunction.h:48)
../../testApp/misc/testThread.cpp: In function ‘void testBasic()’:
../../testApp/misc/testThread.cpp:105: warning: ‘Executor’ is deprecated
(declared at /usr/local/epics/base-7.0.1/include/pv/executor.h:57)
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h: In function
‘void<unnamed>::test_basic()’:
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: warning:
dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h:98: note: initialized
from here
../../testApp/misc/testanyscalar.cpp:54: warning: dereferencing pointer
../../testApp/misc/testanyscalar.cpp:54: note: initialized from here
/usr/local/epics/base-7.0.1/include/pv/typemap.h:16: warning:
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h:85: note: initialized
from here
/usr/local/epics/base-7.0.1/include/pv/typemap.h:17: warning:
from here
/usr/local/epics/base-7.0.1/include/pv/typemap.h:18: warning:
from here
/usr/local/epics/base-7.0.1/include/pv/typemap.h:19: warning:
from here
/usr/local/epics/base-7.0.1/include/pv/typemap.h:20: warning:
from here
../../testApp/misc/testanyscalar.cpp:67: warning: dereferencing pointer
../../testApp/misc/testanyscalar.cpp:67: note: initialized from here
../../testApp/misc/testanyscalar.cpp:69: warning: dereferencing pointer
../../testApp/misc/testanyscalar.cpp:69: note: initialized from here
‘void<unnamed>::test_ctor()’:
from here
../../testApp/misc/testanyscalar.cpp:39: warning: dereferencing pointer
../../testApp/misc/testanyscalar.cpp:39: note: initialized from here
‘void<unnamed>::test_swap()’:
from here
../../testApp/misc/testanyscalar.cpp:126: warning: dereferencing pointer
../../testApp/misc/testanyscalar.cpp:126: note: initialized from here
from here
../../testApp/misc/testanyscalar.cpp:145: warning: dereferencing pointer
../../testApp/misc/testanyscalar.cpp:145: note: initialized from here
from here
../../testApp/misc/testanyscalar.cpp:153: warning: dereferencing pointer
../../testApp/misc/testanyscalar.cpp:153: note: initialized from here
from here
../../testApp/misc/testanyscalar.cpp:159: warning: dereferencing pointer
../../testApp/misc/testanyscalar.cpp:159: note: initialized from here
from here
from here
../../testApp/misc/testanyscalar.cpp:164: warning: dereferencing pointer
../../testApp/misc/testanyscalar.cpp:164: note: initialized from here
../../testApp/misc/testanyscalar.cpp:165: warning: dereferencing pointer
../../testApp/misc/testanyscalar.cpp:165: note: initialized from here
../../testApp/copy/testPVCopy.cpp: In function 'void testPVScalar(const
string&, const string&, const PVStructurePtr&, const PVCopyPtr&)':
../../testApp/copy/testPVCopy.cpp:44:12: warning: variable 'offset' set
but not used [-Wunused-but-set-variable]
testPVScalarArray(const string&, const string&, const PVStructurePtr&,
const PVCopyPtr&)':
../../testApp/copy/testPVCopy.cpp:90:12: warning: variable 'offset' set
../../testApp/misc/testQueue.cpp:68:28: warning: 'Queue' is deprecated
(declared at /usr/local/epics/base-7.0.1/include/pv/queue.h:28)
In file included from ../../src/remote/codec.cpp:40:
../../src/remote/pv/codec.h:294:18: warning: private field
'_socketSendBufferSize' is not used [-Wunused-private-field]
const size_t _socketSendBufferSize;
In file included from ../caProvider.cpp:21:0:
../caChannel.h:93:46: warning: ‘virtual void
epics::pvAccess::ca::CAChannel::destroy()’ is deprecated
virtual void destroy() EPICS_DEPRECATED {};
../caChannel.h:93:18: note: declared here
../caChannel.h:171:46: warning: ‘virtual void
epics::pvAccess::ca::CAChannelGet::destroy()’ is deprecated
../caChannel.h:171:18: note: declared here
../caChannel.h:239:46: warning: ‘virtual void
epics::pvAccess::ca::CAChannelPut::destroy()’ is deprecated
../caChannel.h:239:18: note: declared here
../caChannel.h:302:46: warning: ‘virtual void
epics::pvAccess::ca::CAChannelMonitor::destroy()’ is deprecated
../caChannel.h:302:18: note: declared here
../reftrackioc.cpp: In function 'void {anonymous}::showRefs(const
epics::RefSnapshot&, int, bool)':
../reftrackioc.cpp:29:75: warning: format '%zd' expects argument of type
'signed size_t', but argument 4 has type 'long int' [-Wformat]
../../testApp/remote/testGetPerformance.cpp: In function ‘void get_all()’:
../../testApp/remote/testGetPerformance.cpp:117: warning: ‘virtual void
epics::pvAccess::ChannelProvider::flush()’ is deprecated (declared at
/usr/local/epics/base-7.0.1/include/pv/pvAccess.h:1244)
../../testApp/remote/testGetPerformance.cpp: In function ‘void runTest()’:
../../testApp/remote/testGetPerformance.cpp:324: warning: ‘virtual void
../../testApp/remote/testGetPerformance.cpp:358: warning: ‘virtual void
../../testApp/utils/configurationTest.cpp:35:19: warning: unused
variable 'indata' [-Wunused-const-variable]
static const char indata[] =
../../testApp/utils/configurationTest.cpp:43:19: warning: unused
variable 'expectdata' [-Wunused-const-variable]
static const char expectdata[] =
In file included from ../ntcontinuum.cpp:8:
../pv/ntcontinuum.h:96:14: warning: private field 'dim' is not used
bool dim;
../pv/nthistogram.h:106:14: warning: private field 'dim' is not used
bool dim;
In file included from ../pvaClient.cpp:19:
../pv/pvaClient.h:1742:10: warning:
'epics::pvaClient::PvaClientMonitor::monitorConnect' hides overloaded
virtual function [-Woverloaded-virtual]
void monitorConnect(
../pv/pvaClient.h:1610:18: note: hidden overloaded virtual function
'epics::pvaClient::PvaClientMonitorRequester::monitorConnect' declared
here: type mismatch at 2nd parameter ('const PvaClientMonitorPtr &' (aka
'const shared_ptr<epics::pvaClient::PvaClientMonitor> &') vs 'const
epics::pvData::MonitorPtr &' (aka 'const
shared_ptr<epics::pvAccess::Monitor> &'))
virtual void monitorConnect(epics::pvData::Status const & status,
../pv/pvaClient.h:1746:10: warning:
'epics::pvaClient::PvaClientMonitor::unlisten' hides overloaded virtual
void unlisten(epics::pvData::MonitorPtr const & monitor);
../pv/pvaClient.h:1623:18: note: hidden overloaded virtual function
'epics::pvaClient::PvaClientMonitorRequester::unlisten' declared here:
different number of parameters (0 vs 1)
virtual void unlisten()
../../src/pvAccess/channelLocal.cpp: In member function ‘void
epics::pvDatabase::ChannelRPCLocal::processRequest(const
epics::pvAccess::RPCService::shared_pointer&, const
epics::pvData::PVStructurePtr&)’:
../../src/pvAccess/channelLocal.cpp:828: warning: ‘virtual void
epics::pvDatabase::ChannelRPCLocal::destroy()’ is deprecated (declared
at ../../src/pvAccess/channelLocal.cpp:740)
epics::pvAccess::RPCServiceAsync::shared_pointer&, const
../../src/pvAccess/channelLocal.cpp:846: warning: ‘virtual void
../../src/pvAccess/channelLocal.cpp:857: warning: ‘virtual void
../../test/src/testLocalProvider.cpp: In function ‘void test()’:
../../test/src/testLocalProvider.cpp:74: warning: ‘virtual void
epics::pvDatabase::ChannelProviderLocal::destroy()’ is deprecated
(declared at
/usr/local/epics/base-7.0.1/include/pv/channelProviderLocal.h:124)
../../test/src/testPVAServer.cpp: In function ‘void test()’:
../../test/src/testPVAServer.cpp:70: warning: ‘void
epics::pvAccess::ServerContext::destroy()’ is deprecated (declared at
/usr/local/epics/base-7.0.1/include/pv/serverContext.h:59)
../pdbsingle.cpp:300:64: warning: C++98 requires an accessible copy
constructor for class 'FieldName' when binding a reference to a
temporary; was private [-Wbind-to-temporary-copy]
,pvif(channel->pv->builder->attach(channel->pv->chan, pvf,
FieldName()))
../pvif.h:291:5: note: declared private here
FieldName(const FieldName&);
../pdbsingle.cpp:364:92: warning: C++98 requires an accessible copy
p2p::auto_ptr<PVIF>
putpvif(channel->pv->builder->attach(channel->pv->chan, value,
FieldName()));
../pdbsingle.cpp:386:92: warning: C++98 requires an accessible copy
p2p::auto_ptr<PVIF>
FieldName()));
‘int<unnamed>::conf_integer(void*, epics::pvData::yajl::integer_arg)’:
from here
Dirk
- Re: EPICS 7.0.1-pre1 Michael Davidsaver
- Re: EPICS 7.0.1-pre1 (typeCast.h) Michael Davidsaver
- Re: EPICS 7.0.1-pre1 (pdbsingle.cpp) Michael Davidsaver
- Re: EPICS 7.0.1-pre1 (spinlock.hpp) Dirk Zimoch
- Re: EPICS 7.0.1-pre1 (client.cpp) Dirk Zimoch
- Re: EPICS 7.0.1-pre1 -- vxWorks 6.2 Dirk Zimoch
- Re: EPICS 7.0.1-pre1 (non-virtual destructors) Dirk Zimoch
- Re: EPICS 7.0.1-pre1 (epicsException.h) Dirk Zimoch
- EPICS 7.0.1-pre1 Andrew Johnson
Re: EPICS 7.0.1-pre1 Andrew Johnson
<2017>
<2017>
