2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Possible Access Rights improvement?
To: EPICS Core Talk <[email protected]>
Date: Thu, 24 Aug 2017 20:40:52 +0000
Your calc record example is good.
Assume
record(calc, "ramp")
  field(INPA, "ramp")
  field(CALC, "A+1")
  field(SCAN, "1 second")
In this case you _can_ display the record in a TextEntry field.
Most of the time, the record counts up on its own.
But you can also enter "0" or "1000" to reset the ramp, or move it ahead.
Somewhat tricky to decide inside the IOC if the VAL field should allow write access or not.
It's really up to the person who creates this database to decide:
Do I add access security to make it read-only?
Or do I allow writing, but only to those in-the-know, because on the displays I present it with a Text Update?
Or do I intent for this to be written by mere mortals, so I use a Text Entry on the display?
-Kay
Possible Access Rights improvement? Ralph Lange
Re: Possible Access Rights improvement? Kasemir, Kay
Re: Possible Access Rights improvement? Ralph Lange
Prev: Re: Possible Access Rights improvement? Ralph Lange
Next: Re: Stalled CA connection (IOC to CS-Studio archiver) Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Next: Improved simulation mode prototype Ralph Lange
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
