What is the use case?
Assume I have an AI record that reads from a PLC.
So I display that as a text update field on the UI.
Would you routinely display that record as a text entry field?
-Kay
Dear Core-talkers,
There is a possible request from our operations group to show VAL fields of input records as having no write access, if the device support would overwrite any value written at the next record processing.
Technically, these fields are writable.
Functionally, there are issues:
- The writing client (even using put-callback) will get the new value and show the operation as having succeeded.
- Other clients doing gets or creating new subscriptions (e.g. newly opened panels) will see the new value.
- Existing subscriptions (e.g. archivers, gateways, already open panels) will not get an update and have no clue.
- Depending on the situation (DTYP, SCAN) this inconsistent state may last a while.
What are your thoughts on this?
~Ralph
- Re: Possible Access Rights improvement? Ralph Lange
- Possible Access Rights improvement? Ralph Lange
Improved simulation mode prototype Ralph Lange
<2017>
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
