2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: pvaSrv "can not monitor a link field"
To: [email protected]
Date: Mon, 22 May 2017 19:38:15 -0400
On 05/22/2017 04:13 PM, Kasemir, Kay wrote:
> Hi:
> I followed Michael's instructions from https://github.com/mdavidsaver/v4workspace/tree/pva2pva .
> Builds OK, just had to manually edit the RELEASE.local.in into a RELEASE.local, not sure if there's an automake way to handle that.
> Also couldn't find "qsrv" as such, but in the end the pva2pva/bin/linux-x86_64/softIocPVA contains a PVA server, there's no need to add anything to the st.cmd.
Look for qsrvSupport.dbd.  At the moment, the associated library is
libpdbcore.so, which as I look at it now is wrong.  I'll be changing
this to libqsrv.so soon.
The softIocPVA executable is built from softIoc.dbd and qsrvSupport.dbd.
> With that, I can monitor link fields.
> Also, not having to add anything to the st.cmd file to get the PVA server started is nice.
> So this limited test suggests replacing pvaSrv with qsrv.
> Thanks,
> Kay
> From: Michael Davidsaver <[email protected]>
> Sent: Monday, May 22, 2017 10:58 AM
> To: Ralph Lange; Kasemir, Kay
> Cc: EPICS Core Talk
> On 05/22/2017 10:48 AM, Ralph Lange wrote:
>> Depending on what the release plans for QSRV are (@Michael?),
>> You actually might want to add this as an issue to pvaSrv.
> I was just about to ask Kay if he would be willing to test QSRV,
>> Thanks a lot,
>> ~Ralph
>> ps. We need more unit tests.
>> On Mon, May 22, 2017 at 11:29 PM, Kasemir, Kay <[email protected]
>> <mailto:[email protected]>> wrote:
>>     Hi:
>>     This came up during the V4 introduction at the recent EPICS meeting.
>>     I first thought it's a bug in CS-Studio, but instead it's a
>>     limitation in pvaSrv.
>>     Assume an IOC with pvaSrv added to it, take any calc or ai record:
>>     pvget that_record
>>     -> fine
>>     pvget that_record.INP (or INPA for a calc record)
>>     -> fine
>>     pvget -m that_record
>>     -> fine
>>     pvget -m that_record.INP (or INPA for a calc record)
>>     -> Don't get a value, instead message(can not monitor a link field,
>>     error)
>>     monitorConnect(Status [type=ERROR, message=create dbPvMonitor failed])
>>     Checking the 4.6.0 release of V4, pvaSrv/src/dbPv/[3.14,
>>     3.15]/dbPvMonitor.cpp both check for link fields and refuse to
>>     monitor them with this error message.
>>     Fundamentally, 'camonitor' can monitor link fields, and there are
>>     some use cases for doing this:
>>     Displays (EDM, CSS, ..) sometimes need to put 'INP' links on the
>>     display so that users can change the input.
>>     The CSS EPCIS PV Tree tool monitors input links to show the link
>>     hierarchy.
>>     Is monitoring link fields supported in QSRV?
>>     Thanks,
>>     Kay
pvaSrv "can not monitor a link field" Kasemir, Kay
Re: pvaSrv "can not monitor a link field" Ralph Lange
Re: pvaSrv "can not monitor a link field" Michael Davidsaver
Re: pvaSrv "can not monitor a link field" Kasemir, Kay
Prev: Re: pvaSrv "can not monitor a link field" Kasemir, Kay
Next: Build failed in Jenkins: epics-base-3.16-linux32-test #77 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
