Hi Andrew,
That would be awesome. (EPICS tests don't work well with Appveyor CI because that doesn't understand TAP.) Meanwhile I was looking at which seems to add more complete information. See the example xml in the README on GitHub. Not implemented in Perl, obviously. As it is not related to any code, I would add it to all branches that we build using CI: 3.14/3.15/3.16 Related issue: Can we make the tap or xunit targets also print the summary line (Result: PASS etc.) on stdout, i.e. add the commands that Michael uses on Travis? (find . -name '*.tap' -print0 | xargs -0 -n1 prove -e cat -f). That would make grep'ing the make output (scrolling back or by script) a lot easier when running the tap/xunit style. Cheers, ~Ralph
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
