2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: Interest in JUnit xml Test Results?
To: <[email protected]>
Date: Thu, 18 May 2017 17:29:22 -0500
On 05/16/2017 01:49 AM, Ralph Lange wrote:
> As it is not related to any code, I would add it to all branches that we
> build using CI: 3.14/3.15/3.16
Committed and merged up.
Don't forget to install the Perl XML::Generator module when using this...
> Related issue:
> Can we make the tap or xunit targets also print the summary line
> (Result: PASS etc.) on stdout, i.e. add the commands that Michael uses
> on Travis? (find .-name '*.tap'-print0 |xargs -0 -n1 prove -e cat -f).
> That would make grep'ing the make output (scrolling back or by script) a
> lot easier when running the tap/xunit style.
I have been adding an equivalent (prove --failure) to the end of my
build scripts, let me know if you find any specific jobs that I've missed.
- Andrew
Interest in JUnit xml Test Results? Andrew Johnson
Re: Interest in JUnit xml Test Results? Ralph Lange
Prev: Re: Interest in JUnit xml Test Results? Ralph Lange
Next: Build failed in Jenkins: epics-base-3.16-mac-test #102 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
