See <https://jenkins.aps.anl.gov/job/epics-base-3.16/104/display/redirect>
Started by an SCM change
[EnvInject] - Loading node environment variables.
Building on master in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16/ws/>
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
> git --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
> git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:809)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1076)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1107)
at hudson.scm.SCM.checkout(SCM.java:496)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1278)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:604)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:529)
at hudson.model.Run.execute(Run.java:1728)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:98)
at hudson.model.Executor.run(Executor.java:405)
Caused by: hudson.plugins.git.GitException: Command "git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: error: RPC failed; result=22, HTTP code = 500
fatal: The remote end hung up unexpectedly
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1833)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1552)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:66)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:343)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:807)
... 11 more
ERROR: null
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.linux-x86_64/*.tap
Saving reports...
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/arrShorthandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/arrShorthandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/callbackParallelTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/callbackParallelTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/callbackTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/callbackTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/chfPluginTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/chfPluginTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbCaLinkTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbCaLinkTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbCaStatsTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbCaStatsTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbChArrTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbChArrTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbChannelTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbChannelTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbLockTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbLockTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbPutLinkTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbPutLinkTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbScanTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbScanTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbShutdownTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbShutdownTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbStateTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbStateTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbStaticTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbStaticTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbStressTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/dbStressTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/recGblCheckDeadbandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/recGblCheckDeadbandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/scanIoTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/scanIoTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/testPutGetTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/testPutGetTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/testdbConvert.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/db/test/O.linux-x86_64/testdbConvert.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/dbtemplate/test/O.linux-x86_64/msi.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/ioc/dbtemplate/test/O.linux-x86_64/msi.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/blockingSockTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/blockingSockTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsAlgorithmTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsAlgorithmTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsAtomicTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsAtomicTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsCalcTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsCalcTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsEllTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsEllTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsEnvTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsEnvTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsErrlogTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsErrlogTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsEventTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsEventTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsExitTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsExitTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsInlineTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsInlineTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMMIOTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMMIOTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMathTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMathTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMessageQueueTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMessageQueueTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMutexTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsMutexTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsSockResolveTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsSockResolveTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsSpinTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsSpinTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsStackTraceTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsStackTraceTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsStdioTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsStdioTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsStdlibTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsStdlibTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsStringTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsStringTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadHooksTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadHooksTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadOnceTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadOnceTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadPoolTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadPoolTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadPriorityTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadPriorityTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadPrivateTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadPrivateTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsThreadTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTimeTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTimeTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTimeZoneTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTimeZoneTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTimerTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTimerTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTypesTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsTypesTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsUnitTestTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/epicsUnitTestTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/ipAddrToAsciiTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/ipAddrToAsciiTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/macDefExpandTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/macDefExpandTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/macLibTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/macLibTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/ringBytesTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/ringBytesTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/ringPointerTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/ringPointerTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/taskwdTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/libCom/test/O.linux-x86_64/taskwdTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/filters/test/O.linux-x86_64/arrTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/filters/test/O.linux-x86_64/arrTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/filters/test/O.linux-x86_64/dbndTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/filters/test/O.linux-x86_64/dbndTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/filters/test/O.linux-x86_64/syncTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/filters/test/O.linux-x86_64/syncTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/filters/test/O.linux-x86_64/tsTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/filters/test/O.linux-x86_64/tsTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/rec/test/O.linux-x86_64/analogMonitorTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/rec/test/O.linux-x86_64/analogMonitorTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/rec/test/O.linux-x86_64/arrayOpTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/rec/test/O.linux-x86_64/arrayOpTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/rec/test/O.linux-x86_64/asTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/rec/test/O.linux-x86_64/asTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/rec/test/O.linux-x86_64/compressTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/rec/test/O.linux-x86_64/compressTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/rec/test/O.linux-x86_64/linkRetargetLinkTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/rec/test/O.linux-x86_64/linkRetargetLinkTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/rec/test/O.linux-x86_64/regressTest.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/std/rec/test/O.linux-x86_64/regressTest.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Breaktable.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Breaktable.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/DBD.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/DBD.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Device.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Device.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Driver.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Driver.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Function.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Function.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Menu.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Menu.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Recfield.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Recfield.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Recordtype.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Recordtype.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Registrar.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Registrar.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Snippets.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Snippets.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Variable.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/Variable.tap].
Processing '/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/macLib.tap'
Parsing TAP test result [/var/lib/jenkins/jobs/epics-base-3.16/builds/104/tap-master-files/src/tools/test/O.linux-x86_64/macLib.tap].
TAP Reports Processing: FINISH
[WARNINGS] Skipping publisher since build result is FAILURE
Archiving artifacts
- Build failed in Jenkins: epics-base-3.16 #105 APS Jenkins
Jenkins build is back to normal : epics-base-3.16-win32-test #59 APS Jenkins
<2017>
Jenkins build is back to normal : epics-base-3.16-mac-test #87 APS Jenkins
<2017>
