2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP
To: "Rivers, Mark L." <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Mon, 19 Sep 2016 03:12:05 +0000
> What command do I issue in the top-level repository to ensure that all submodules are at the correct version for 4.6.0 of the top-level?
You may be able to say
    git submodule update
but I'm not sure if that always works. You can do
    git submodule status
and you'll get a list of the states of the submodules and compare them with the contents of the documentation/git-versions file to be sure, but you might have to go into any submodule that is not correctly checked out and do a
    git checkout 4.2.2
or similar depending on the tag to fix it.
- Andrew
Sent from my iPad
RE: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Mark Rivers
Re: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Johnson, Andrew N.
Prev: Re: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Johnson, Andrew N.
Next: RE: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Mark Rivers
ANJ, 18 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
