2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP
To: "Rivers, Mark L." <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Sun, 18 Sep 2016 17:41:27 +0000
Hi Mark,
On Sep 8, 2016, at 10:28 AM, Mark Rivers <[email protected]> wrote:
> I get the following errors when running  "make -sj clean" on windows-x64 in top-level of pvPackageCPP
My pvPackageCPP module has been superseded by the bundleCPP module at [email protected]:epics-base/bundleCPP.git which handles parallel builds much better, but is really designed for creating the full C++ release. The release/4.6.0 branch of that module now points to the V4 modules as at the 4.6.0 release which is being made today. The master branch of that module does *not* have the latest versions of the submodules, so make sure you use the right branch.
> I would also really like to be able to do “make realclean” and “make realuninstall” in that top-level directory, but that is not supported.
The bundleCPP module does support ‘make distclean’ although I’m not too sure about doing that in parallel.
- Andrew
RE: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Mark Rivers
Prev: EPICS 3.15.4 on RTEMS rtems-4.11.99.0 (PowerPC/Generic (classic FPU)/beatnik) Heinz Junkes
Next: RE: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Errors when running "make -sj clean" on windows-x64 in top-level of pvPackageCPP Mark Rivers
ANJ, 18 Sep 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
