On 19/12/2015 17:24, Johnson, Andrew N. wrote:
Please bear in mind that the code that you posted comes from the CA client, not the CA Repeater, and it's the repeater that sees the UDP packets — C++ clients get their beacons over TCP from the repeater. Inside ca_repeater() there is a statement that copies the beacon source IP address into a field of the beacon message before redistributing it, provided that address was zero in the incoming UDP message. The comments immediately above your code snippet describe this, although they call the repeater something like a fan-out server. I was reading through this yesterday and the code I looked at matched up with the comments, but I didn't check the code that actually generates the beacons.
Correct.
But that copying of the UDP sender address happens only if the message
content was empty (zero), which is the behavior of old servers. New
servers (that how I interpret that comments) do fill in the message
content on the server side, which means that it does not get overwritten
by the repeater or client.
Also, Anze's wireshark data is taken from the network, not the local
socket between client and caRepeater. This makes me pretty sure his
server is new enough to fill in the beacon message contents itself.
The sending code is in rsrv/online_notify.c, lines 240ff.
For each element in the list of beacon addresses to send to, it
connect()s the beacon socket, then calls getsockname() on it and puts
the address it gets inside the beacon message.
I don't know whether the Java library relies on the repeater so it might do things differently. Presumably Anze is using 3.15.3, could you also check against a 3.14.12 IOC in case the multi-interface changes in 3.15 broke the beacon generation code.
As far as I know, Anze is using a 3.14.12 IOC, and the single-interface
changes in 3.15 do not apply.
Cheers,
~Ralph
- Fwd: Wrong beacon source IP address Ralph Lange
- Re: Fwd: Wrong beacon source IP address Michael Davidsaver
- Re: Fwd: Wrong beacon source IP address Andrew Johnson
- Re: Fwd: Wrong beacon source IP address Ralph Lange
- Re: Wrong beacon source IP address Johnson, Andrew N.
<2015>
<2015>
