On 12/18/2015 05:39 PM, Andrew Johnson wrote:
> I mis-read Anze's original description, and it now sounds to me like
> there may be a bug in his network stack.
It seems the answer is no, or at least that the "bug" is the default. I tested using a VM with 3 NICs and see the described behavior.
I should note that the VM host is behaving a little odd (I think) as a 'ping -I <ethX> <addr>' of the VM host using mismatched interface and address does succeed. wireshark shows the echo request going out on the specified interface.
Note: For this test I use qemu w/ 3 NICs, 1 is the usermode stack and two taps. No special IP routes, and forwarding is not enabled.
> Is it really possible to send
> out a broadcast UDP message that has a different IP source address than
> the address of the network interface you're sending it out from?
Seems a bit bizarre, but apparently possible.
> I would
> expect something like that to only be possible if you're running as root.
No root needed.
> Could this me something to do with the configuration of his virtual
> network ports, or with his Wireshark setup? I would like to see this
> experiment repeated on a machine that has multiple real interfaces,
> because it doesn't make sense to me.
I also tested with https://github.com/mdavidsaver/epics-base/tree/rsrvbindiface
which does things a little differently. The new code shows consistent source and destination addresses.
So I suspect this is an artifact of using a connect()'d UDP socket vs. sendto(). In both cases an implicit bind() is done, and my guess would be that for connect() the bind selects a single interface while sendto() picks the wildcard. (assuming such intuitive behavior for bsd sockets may not be a good idea on my part :P )
signature.asc
Description: OpenPGP digital signature
- Fwd: Wrong beacon source IP address Ralph Lange
- Re: Fwd: Wrong beacon source IP address Michael Davidsaver
- Re: Fwd: Wrong beacon source IP address Andrew Johnson
Re: Wrong beacon source IP address Ralph Lange
<2015>
Fwd: Re: Wrong beacon source IP address Ralph Lange
<2015>
