2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Build failed in Jenkins: epics-base-3.16-vx69 #1
To: [email protected]
Date: Mon, 9 Feb 2015 17:24:41 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-vx69/1/>
Started by upstream project "epics-base-3.16" build number 2
originally caused by:
 Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building on master in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-vx69/ws/>
[NODE STALKER] The job epics-base-3.16-linux64 does not exist! Please check your configuration!
[workspace] $ /bin/sh -xe /tmp/hudson3806639774362141230.sh
+ make vxWorks-ppc32sf
make: *** No rule to make target `vxWorks-ppc32sf'.  Stop.
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.16-vx69 #2 APS Jenkins
Prev: Build failed in Jenkins: EPICS 3.16 » base-ios #2 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-vx68 #1 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Jenkins build is back to normal : epics-base-3.16-vx69 #2 APS Jenkins
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
