2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Build failed in Jenkins: EPICS 3.16 » base-ios #2
To: [email protected]
Date: Mon, 9 Feb 2015 15:40:24 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-3.16/job/base-ios/2/>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on mac-1 (mac) in workspace <https://jenkins.aps.anl.gov/job/epics-3.16/job/base-ios/ws/>
[NODE STALKER] The job epics-3.16/base-mac does not exist! Please check your configuration!
[base-ios] $ /bin/sh -xe /var/folders/6f/2q91ldsx2rncqbx80st_4r700000gn/T/hudson7757002463707248543.sh
+ make ios-arm
make: *** No rule to make target `ios-arm'.  Stop.
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: EPICS 3.16 » base-ios #1 APS Jenkins
Prev: Build failed in Jenkins: EPICS 3.16 » base-ios #1 APS Jenkins
Next: Build failed in Jenkins: epics-base-3.16-vx69 #1 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
