g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base
To: Ralph Lange <Ralph.Lange@gmx.de>
Date: Wed, 04 Jul 2012 18:29:17 -0000
Review: Approve
Hi Ralph,
I made some minor changes while merging this, the most important being to properly fix the vxWorks epicsThreadInit() code so it is only run once.  I also renamed a few things so the hooking API is now called epicsThreadHookAdd(), and I added the test routine to epicsRunLibComTests().
I'll do a test run on vxWorks when I'm back at work tomorrow.
- Andrew
https://code.launchpad.net/~ralph-lange/epics-base/thread-hooks/+merge/112806
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
[Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
Prev: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
Next: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base noreply
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
