Subject: |
Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base |
Ralph Lange <[email protected]> |
To: |
Andrew Johnson <[email protected]> |
Date: |
Tue, 03 Jul 2012 13:35:21 -0000 |
> [...] The _main_ thread gets its epicsThreadOSD structure created and
> added to pthreadList inside the once() routine in od/posix/osdThread.c before
> epicsThreadHooksInit() is run. The Init() routine cannot call any other
> epicsThread... routines such as epicsThreadGetIdSelf() because once() hasn't
> finished yet.
I don't like all thread start hooks to inherit this limitation, so I implemented this using a second default hook, that is exclusively used for _main_.
So - if I did not miss anything - the list seems to be worked through, again.
~Ralph
https://code.launchpad.net/~ralph-lange/epics-base/thread-hooks/+merge/112806
Your team EPICS Core Developers is requested to review the proposed merge of lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base.
- Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Andrew Johnson
Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
<2012>
<2012>
