2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Base 3.14.12.2-pre1 available for testing
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Mon, 28 Nov 2011 13:42:57 -0600
Hi Benjamin,
On 2011-11-25 Benjamin Franksen wrote:
> Compiling this under windows gives a link error 'symbol dbBptNotMonotonic
> not defined'. See https://bugs.launchpad.net/bugs/894276. The solution is
> to properly declare this variable in a header file (dbStaticLib.h) with
> epicsShareExtern (is the cleaner solution anyway). A patch for this fix is
> attached. It solves the problem on Windows for me (32bit VM).
I applied an equivalent patch (I hadn't committed your original change
verbatim so it needed a slightly different fix) and tested on Mingw, Cygwin
and Win32.  The change has been committed to LP.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
EPICS Base 3.14.12.2-pre1 available for testing Andrew Johnson
Re: EPICS Base 3.14.12.2-pre1 available for testing Andrew Johnson
Re: EPICS Base 3.14.12.2-pre1 available for testing Benjamin Franksen
Prev: Re: EPICS Base 3.14.12.2-pre1 available for testing Benjamin Franksen
Next: EPICS Contract Position - Please alert your subscribers. Ken Reed
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Contribtions for R3.14.12.2-rc1 Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
