2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Base 3.14.12.2-pre1 available for testing
To: [email protected]
Date: Mon, 21 Nov 2011 11:34:52 -0600
Hi Ben,
On 2011-11-18 Benjamin Franksen wrote:
> It may be a bit late but I have attached a very small patch that adds an
> option -b to dbExpand to enable the relaxed breakpoint table checking on
> the host side. Please consider merging this into R3.14.12.2.
Merged, thanks.
> Please bear with me for not going through the bazaar merge process with
> this, but I just now discovered the breakpoint table problem when trying to
> upgrade an existing application to 3.14.12. Splitting all the tables off
> from the main dbd and loading them separately would be a major effort for
> us. Note that the patch is almost trivial (I tested that it works with and
> without the new -b option).
Not a problem; I only ask for a Bazaar branch with significant code changes
that should undergo wider testing and review.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: EPICS Base 3.14.12.2-pre1 available for testing Benjamin Franksen
EPICS Base 3.14.12.2-pre1 available for testing Andrew Johnson
Prev: Re: EPICS Base 3.14.12.2-pre1 available for testing Benjamin Franksen
Next: Contribtions for R3.14.12.2-rc1 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: EPICS Base 3.14.12.2-pre1 available for testing Benjamin Franksen
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
