Subject: |
Re: [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
Jeff Hill <[email protected]> |
Date: |
Sat, 27 Aug 2011 00:02:31 -0000 |
This doesn't fully cover all our architectures yet.
Both darwin and linux can build Base using clang, but when I use clang on Linux with the gcc header it doesn't hit the #error in compiler/gcc/compilerSpecific.h since clang defines __GNUC__ anyway. There needs to be an easy way to make that switch (including setting CC and CCC) based on a single CONFIG_SITE setting.
Jeff: I'm happy to work on implementing these fixes back at ANL. Have you based your atomic branch on this one? I'd like to drop your 12229 merge commit, but that would probably mess you up if I did.
- Andrew
https://code.launchpad.net/~epics-core/epics-base/3.15-buildCompilerSpecific/+merge/72258
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base.
- [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base Jeff Hill
[Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base noreply
[Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Andrew Johnson
<2011>
Re: [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base Jeff Hill
<2011>
