Subject: |
Re: [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base |
Jeff Hill <[email protected]> |
To: |
Date: |
Wed, 31 Aug 2011 23:59:22 -0000 |
your changes look good
> Both darwin and linux can build Base using clang, but when I use clang on Linux
> with the gcc header it doesn't hit the #error in compiler/gcc/compilerSpecific.h
> since clang defines __GNUC__ anyway. There needs to be an easy way to make that
> switch (including setting CC and CCC) based on a single CONFIG_SITE setting.
I suspect that you now see that I did implement a clang specific compilerDependent.h.
I did include a #warning in that file because I don't yet have clang installed here
and it hasn't been tested.
I see that you added a commented out compiler class definition (which will cause the
clang specific file to be used) for clang in multiple places. Perhaps we can
conditionally include a clang specific configure file as we do with gcc so that
this can be consolidated? The typical approach is to add a suffix to the
arch - i.e. linux-x86-clang. That probably needs to be done, but it probably
should be considered orthogonal to this merge proposal (I prefer not to
block other layered merges)
> Have you based your atomic branch on this one? I'd like to drop your 12229 merge
> commit, but that would probably mess you up if I did.
For this branch I started with R3.15, and copied stuff over from the atomics branch.
I do have the following code in the atomics branch so it does apparently have 12229 but I
might have manually copied in the change.
833 + * Deprecation marker if possible
834 + */
835 +#if (__GNUC__ > 2)
836 +# define EPICS_DEPRECATED __attribute__((deprecated))
837 +#else
838 +# define EPICS_DEPRECATED
839 +#endif
https://code.launchpad.net/~epics-core/epics-base/3.15-buildCompilerSpecific/+merge/72258
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base.
- Re: [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base Andrew Johnson
- [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base Jeff Hill
[Merge] lp:~johill-lanl/epics-base/epicsThreadOnce-atomics-based into lp:epics-base Jeff Hill
[Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
<2011>
<2011>
