Subject: |
Re: [Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
Date: |
Thu, 25 Aug 2011 23:17:30 -0000 |
Review: Approve
A few minor things which I will correct while merging:
* This code uses C++ comments in C files (which GCC accepts, but some compilers don't).
* The test code uses status values which are not related to the code being tested as test pass/fail results.
* New release note entries go at the top of the file, not the bottom.
https://code.launchpad.net/~mshankar/epics-base/softioclogging/+merge/72816
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
- [Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base Andrew Johnson
[Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base noreply
<2011>
<2011>
