Subject: |
[Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 25 Aug 2011 00:35:13 -0000 |
Andrew Johnson has proposed merging lp:~mshankar/epics-base/softioclogging into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~mshankar/epics-base/softioclogging/+merge/72816
Codeathon: Add logClientPrefix command and functionality.
This branch includes code, tests and release notes.
AppDevGuide entry also supplied separately.
Your team EPICS Core Developers is requested to review the proposed merge of lp:~mshankar/epics-base/softioclogging into lp:epics-base.
=== modified file 'documentation/RELEASE_NOTES.html'
--- documentation/RELEASE_NOTES.html 2011-08-23 23:19:55 +0000
+++ documentation/RELEASE_NOTES.html 2011-08-25 00:35:04 +0000
@@ -280,5 +280,15 @@
Removed the 3.13 <top>/config directory and build compatibility rules and
variables, and various conversion documents.</p>
+<h3>
+Added support for iocLogPrefix</h3>
+<p>
+Added a <code>iocLogPrefix</code> command to <code>ioCsh</code>. This establishes a prefix that will be
+common to all log messages as they are sent to the iocLogServer. This lets us use the
+"fac=<<i>facility</i>>" syntax for displaying the facility, process name etc. in log viewers like the
+<code>cmlogviewer<code>.
+</p>
</body>
</html>
=== modified file 'src/libCom/iocsh/libComRegister.c'
--- src/libCom/iocsh/libComRegister.c 2010-05-03 22:26:41 +0000
+++ src/libCom/iocsh/libComRegister.c 2011-08-25 00:35:04 +0000
@@ -191,6 +191,15 @@
errlogPrintfNoConsole("%s\n", args[0].sval);
+/* iocLogPrefix */
+static const iocshArg iocLogPrefixArg0 = { "prefix",iocshArgString};
+static const iocshArg * const iocLogPrefixArgs[1] = {&iocLogPrefixArg0};
+static const iocshFuncDef iocLogPrefixFuncDef = {"iocLogPrefix",1,iocLogPrefixArgs};
+static void iocLogPrefixCallFunc(const iocshArgBuf *args)
+ iocLogPrefix(args[0].sval);
/* epicsThreadShowAll */
static const iocshArg epicsThreadShowAllArg0 = { "level",iocshArgInt};
static const iocshArg * const epicsThreadShowAllArgs[1] = {&epicsThreadShowAllArg0};
@@ -355,6 +364,7 @@
iocshRegister(&errlogInitFuncDef,errlogInitCallFunc);
iocshRegister(&errlogInit2FuncDef,errlogInit2CallFunc);
iocshRegister(&errlogFuncDef, errlogCallFunc);
+ iocshRegister(&iocLogPrefixFuncDef, iocLogPrefixCallFunc);
iocshRegister(&epicsThreadShowAllFuncDef,epicsThreadShowAllCallFunc);
iocshRegister(&threadFuncDef, threadCallFunc);
=== modified file 'src/libCom/log/logClient.c'
--- src/libCom/log/logClient.c 2009-07-09 16:37:24 +0000
+++ src/libCom/log/logClient.c 2011-08-25 00:35:04 +0000
@@ -58,6 +58,11 @@
static const double LOG_SERVER_SHUTDOWN_TIMEOUT = 30.0; /* sec */
+ * The logClientPrefix stores a prefix that is sent as a prefix for all log messages.
+static char* logClientPrefix = NULL;
* logClientClose ()
static void logClientClose ( logClient *pClient )
@@ -160,21 +165,13 @@
- * logClientSend ()
+ * private method with code refactored out of logClientSend.
+ * This method relies on the mutex being obtained on pClient->mutex (which happens in logClientSend prior to this method being called)
-void epicsShareAPI logClientSend ( logClientId id, const char * message )
- logClient * pClient = ( logClient * ) id;
+static void sendLogMessageinChunks(logClient * pClient, const char * message) {
unsigned strSize;
- if ( ! pClient || ! message ) {
- return;
strSize = strlen ( message );
- epicsMutexMustLock ( pClient->mutex );
while ( strSize ) {
unsigned msgBufBytesLeft =
sizeof ( pClient->msgBuf ) - pClient->nextMsgIndex;
@@ -231,10 +228,31 @@
break;
+ * logClientSend ()
+void epicsShareAPI logClientSend ( logClientId id, const char * message )
+ logClient * pClient = ( logClient * ) id;
+ if ( ! pClient || ! message ) {
+ return;
+ epicsMutexMustLock ( pClient->mutex );
+ if(logClientPrefix) {
+ sendLogMessageinChunks(pClient, logClientPrefix);
+ sendLogMessageinChunks(pClient, message);
epicsMutexUnlock (pClient->mutex);
void epicsShareAPI logClientFlush ( logClientId id )
@@ -553,5 +571,33 @@
pClient->sock==INVALID_SOCKET?"INVALID":"OK",
pClient->connectCount);
+ printf ("log client: a log prefix has been set \"%s\"\n", logClientPrefix);
+ * iocLogPrefix()
+void epicsShareAPI iocLogPrefix(const char* prefix)
+ // If we have already established a log prefix, do not let the user change it
+ // Note iocLogPrefix is expected to be set in the cmd file during initialization.
+ // We do not anticipate changing this after it has been set
+ printf ("log client: a log prefix has already been established \"%s\". Ignoring this call \n", logClientPrefix);
+ return;
+ if(prefix) {
+ unsigned prefixLen = strlen(prefix);
+ if(prefixLen > 0) {
+ char* localCopy = malloc(prefixLen+1);
+ strcpy(localCopy, prefix);
+ logClientPrefix = localCopy;
=== modified file 'src/libCom/log/logClient.h'
--- src/libCom/log/logClient.h 2005-11-22 00:28:17 +0000
+++ src/libCom/log/logClient.h 2011-08-25 00:35:04 +0000
@@ -33,6 +33,7 @@
epicsShareFunc void epicsShareAPI logClientSend (logClientId id, const char *message);
epicsShareFunc void epicsShareAPI logClientShow (logClientId id, unsigned level);
epicsShareFunc void epicsShareAPI logClientFlush (logClientId id);
+epicsShareFunc void epicsShareAPI iocLogPrefix(const char* prefix);
/* deprecated interface; retained for backward compatibility */
/* note: implementations are in iocLog.c, not logClient.c */
=== modified file 'src/libCom/test/epicsErrlogTest.c'
--- src/libCom/test/epicsErrlogTest.c 2011-03-01 21:03:33 +0000
+++ src/libCom/test/epicsErrlogTest.c 2011-08-25 00:35:04 +0000
@@ -22,6 +22,11 @@
#include "errlog.h"
#include "epicsUnitTest.h"
#include "testMain.h"
+#include "iocLog.h"
+#include "logClient.h"
+#include "envDefs.h"
+#include "osiSock.h"
+#include "fdmgr.h"
#define LOGBUFSIZE 2048
@@ -75,6 +80,27 @@
int jam;
} clientPvt;
+static void testLogPrefix(void);
+static void acceptNewClient( void *pParam );
+static void readFromClient( void *pParam );
+static void testPrefixLogandCompare( const char* logmessage);
+static void *pfdctx;
+static SOCKET sock;
+static SOCKET insock;
+static const char* prefixactualmsg[]= {
+ "A message without prefix",
+ "A message with prefix",
+ "DONE"
+static const char prefixexpectedmsg[] = "A message without prefix"
+ "fac=LI21 A message with prefix"
+ "fac=LI21 DONE"
+static char prefixmsgbuffer[1024];
static
void logClient(void* raw, const char* msg)
@@ -115,7 +141,7 @@
char msg[256];
clientPvt pvt, pvt2;
- testPlan(25);
+ testPlan(35);
strcpy(msg, truncmsg);
@@ -289,5 +315,143 @@
/* Clean up */
errlogRemoveListener(&logClient);
+ testLogPrefix();
return testDone();
+ * Tests the log prefix code
+ * Since the log prefix is only applied to log messages as they are going out on the socket,
+ * we need to create a server listening on a port, accept connections etc.
+ * This code is a reduced version of the code in iocLogServer.
+static void testLogPrefix(void) {
+ struct sockaddr_in serverAddr;
+ int status;
+ struct timeval timeout;
+ struct sockaddr_in actualServerAddr;
+ osiSocklen_t actualServerAddrSize;
+ testDiag("Testing iocLogPrefix");
+ timeout.tv_sec = 5; /* in seconds */
+ timeout.tv_usec = 0;
+ memset((void*)prefixmsgbuffer, 0, sizeof prefixmsgbuffer);
+ /* Clear "errlog: <n> messages were discarded" status */
+ errlogPrintfNoConsole(".");
+ errlogFlush();
+ sock = epicsSocketCreate(AF_INET, SOCK_STREAM, 0);
+ testOk1(sock != INVALID_SOCKET);
+ // We listen on a an available port.
+ memset((void *)&serverAddr, 0, sizeof serverAddr);
+ serverAddr.sin_family = AF_INET;
+ serverAddr.sin_port = htons(0);
+ status = bind (sock,
+ (struct sockaddr *)&serverAddr,
+ sizeof (serverAddr) );
+ testOk1(status >= 0);
+ status = listen(sock, 10);
+ // Determine the port that the OS chose
+ actualServerAddrSize = sizeof actualServerAddr;
+ memset((void *)&actualServerAddr, 0, sizeof serverAddr);
+ status = getsockname(sock, (struct sockaddr *) &actualServerAddr, &actualServerAddrSize);
+ char portstring[16];
+ sprintf(portstring, "%d", ntohs(actualServerAddr.sin_port));
+ testDiag("Listening on port %s", portstring);
+ // Set the EPICS environment variables for logging.
+ epicsEnvSet ( "EPICS_IOC_LOG_INET", "localhost" );
+ epicsEnvSet ( "EPICS_IOC_LOG_PORT", portstring );
+ pfdctx = (void *) fdmgr_init();
+ testOk1(pfdctx != NULL);
+ status = fdmgr_add_callback(
+ pfdctx,
+ sock,
+ fdi_read,
+ acceptNewClient,
+ &serverAddr);
+ status = iocLogInit ();
+ fdmgr_pend_event(pfdctx, &timeout);
+ testPrefixLogandCompare(prefixactualmsg[0]);
+ iocLogPrefix("fac=LI21 ");
+ testPrefixLogandCompare(prefixactualmsg[1]);
+ testPrefixLogandCompare(prefixactualmsg[2]);
+ close(sock);
+static void testPrefixLogandCompare( const char* logmessage ) {
+ errlogPrintfNoConsole(logmessage);
+ errlogFlush();
+ iocLogFlush();
+static void acceptNewClient ( void *pParam )
+ osiSocklen_t addrSize;
+ struct sockaddr_in addr;
+ int status;
+ addrSize = sizeof ( addr );
+ insock = epicsSocketAccept ( sock, (struct sockaddr *)&addr, &addrSize );
+ testOk1(insock!=INVALID_SOCKET && addrSize >= sizeof (addr) );
+ pfdctx,
+ insock,
+ fdi_read,
+ readFromClient,
+ NULL);
+static void readFromClient(void *pParam)
+ char recvbuf[1024];
+ int recvLength;
+ memset(&recvbuf, 0, 1024);
+ recvLength = recv(insock,
+ &recvbuf,
+ 1024,
+ 0);
+ if (recvLength > 0) {
+ strcat(prefixmsgbuffer, recvbuf);
+ // If we have received all of the messages.
+ if(strstr(prefixmsgbuffer, "DONE") != NULL) {
+ int prefixcmp = strncmp(prefixexpectedmsg, prefixmsgbuffer, strlen(prefixexpectedmsg));
+ if(prefixcmp != 0) {
+ printf("Expected %s\n", prefixexpectedmsg);
+ printf("Obtained %s\n", prefixmsgbuffer);
+ testOk1(prefixcmp == 0);
- Re: [Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base Andrew Johnson
- [Merge] lp:~mshankar/epics-base/softioclogging into lp:epics-base noreply
Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Andrew Johnson
<2011>
[Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base noreply
<2011>
