2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base
To: [email protected]
Date: Thu, 27 May 2010 10:39:26 -0000
Hello,
I committed a set of modifications based on your comments. The ezca strings are gone in favour of "DBF_" strings. The prefix is arbitrary and it's only an indication for the printField function for how to print a field.
My testing was limited to records of type ai, calc, mbbo, all running locally on the same PC. Thanks for testing it on non-EPICS pvs!
I have now found the limitations of the parser. It chokes when, say, a description includes the word "field". In my case it was on an sseq record.
Ronaldo
https://code.launchpad.net/~ronaldo-mercado/epics-base/capr/+merge/26037
Your team EPICS Core Developers is requested to review the proposed merge of lp:~ronaldo-mercado/epics-base/capr into lp:epics-base.
[Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ronaldo Mercado
Prev: Re: [Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base Kim, Kukhee
Next: RE: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ronaldo Mercado
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ronaldo Mercado
Next: [Merge] lp:~dirk.zimoch/epics-base/non-val-attributes into lp:epics-base Dirk Zimoch
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
