Ralph Lange wrote:
This is a non-trivial and somewhat delicate issue.
Andrew is right: If a certain gateway's priority should be higher or
lower than other clients' priorities strictly depends on your system
design. For a gateway to the outside world you would want a low
priority to minimize impact on your IOCs, for a gateway to the control
room, you would want the priority to be somewhat higher.
We have different types of gateways.
For gateways, that our simply used to load balance an IOC(s) deep within
the control system; would be good to specify a higher
priority. So that other IOCs and high-level applications such as
MATLAB applications get the benefit.
I would also say that adding a command line option to replace the
hard-coded setting would be the next best step.
Sounds good.
Priority by channel? I don't know. The priority sets the task
priorities for the TCP task pair on the server (IOC) side. which is
only one pair per client. So - does CA even allow different priorities
between one client and the IOC? (I don't think so, but I might be wrong.)
Even if it did, what should the gateway do if ten different clients
ask for the same channel with ten different priorities? Average? Take
the lowest? The highest? Open ten connections?
We have to find the right compromise for the gateway between
transparency, performance, and security.
Best regards from my vacation (it's a rainy day, though),
Ralph
Andrew Johnson wrote:
Hi Ernest,
On Tuesday 21 July 2009 11:29:37 Ernest L. Williams Jr. wrote:
Shouldn't connection that the PV gateway has to IOCs be attached with a
high CA Priority?
Not necessarily, that probably depends on the design of your control
system. If you only have OPI connections coming through the gateway
the current setting is probably right.
How do we change this?
The priority of any CA channel connection is controlled by the client
when it connects to the PV, so the gateway could request a higher
priority for the channels on its client-side if it was coded to do
so. However both the calls to ca_create_channel() in the gateway
code currently specify the fixed value CA_PRIORITY_DEFAULT for their
priority. Note that changing the priority of your clients can have
undesirable effects within the IOCs though if you're not careful.
One quick way to raise the priority of your gateway channels would be
to rebuild the gateway to use something like CA_PRIORITY_ARCHIVE
instead, although this would then affect all PVs on all IOCs that the
gateway connects to.
Better solutions might be to add a command-line argument to configure
that fixed value (similar to the -p <prio> option Ralph recently
added to the caget, caput, camonitor and cainfo programs in Base), or
even to make it controllable through the gateway's configuration file
on a per-channel (regexp) basis.
I believe CosyLab has experience in making changes to the gateway
code if you don't have any effort available to do that in-house.
- Andrew
- Re: CA Priority for PV Gateway Andrew Johnson
- Re: CA Priority for PV Gateway Ralph Lange
RE: CA Priority for PV Gateway Jeff Hill
<2009>
<2009>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
