This is a non-trivial and somewhat delicate issue.
Andrew is right: If a certain gateway's priority should be higher or
lower than other clients' priorities strictly depends on your system
design. For a gateway to the outside world you would want a low priority
to minimize impact on your IOCs, for a gateway to the control room, you
would want the priority to be somewhat higher.
I would also say that adding a command line option to replace the
hard-coded setting would be the next best step.
Priority by channel? I don't know. The priority sets the task priorities
for the TCP task pair on the server (IOC) side. which is only one pair
per client. So - does CA even allow different priorities between one
client and the IOC? (I don't think so, but I might be wrong.)
Even if it did, what should the gateway do if ten different clients ask
for the same channel with ten different priorities? Average? Take the
lowest? The highest? Open ten connections?
We have to find the right compromise for the gateway between
transparency, performance, and security.
Best regards from my vacation (it's a rainy day, though),
Ralph
Andrew Johnson wrote:
Hi Ernest,
On Tuesday 21 July 2009 11:29:37 Ernest L. Williams Jr. wrote:
Shouldn't connection that the PV gateway has to IOCs be attached with a
high CA Priority?
Not necessarily, that probably depends on the design of your control system.
If you only have OPI connections coming through the gateway the current
setting is probably right.
How do we change this?
The priority of any CA channel connection is controlled by the client when it
connects to the PV, so the gateway could request a higher priority for the
channels on its client-side if it was coded to do so. However both the calls
to ca_create_channel() in the gateway code currently specify the fixed value
CA_PRIORITY_DEFAULT for their priority. Note that changing the priority of
your clients can have undesirable effects within the IOCs though if you're
not careful.
One quick way to raise the priority of your gateway channels would be to
rebuild the gateway to use something like CA_PRIORITY_ARCHIVE instead,
although this would then affect all PVs on all IOCs that the gateway connects
to.
Better solutions might be to add a command-line argument to configure that
fixed value (similar to the -p <prio> option Ralph recently added to the
caget, caput, camonitor and cainfo programs in Base), or even to make it
controllable through the gateway's configuration file on a per-channel
(regexp) basis.
I believe CosyLab has experience in making changes to the gateway code if you
don't have any effort available to do that in-house.
- Andrew
- Re: CA Priority for PV Gateway Ernest L. Williams Jr.
- Re: CA Priority for PV Gateway Andrew Johnson
<2009>
<2009>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
