2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Base Release 3.14.11 Timetable
To: Ralph Lange <[email protected]>
Cc: Core-Talk <[email protected]>
Date: Tue, 7 Jul 2009 09:44:38 -0500
Hi Ralph,
On Tuesday 07 July 2009 01:02:34 Ralph Lange wrote:
> I noticed that the codeathon project of adding PINI states has been put
> into CVS. Is my impression correct, that the original motivation (having
> a PINI state that allows for PINI processing *after* Channel Access
> started) somehow disappeared from the radar, and there's still no PINI
> state with working CA links?
As of late last week there are two PINI states called RUNNING and PAUSED which
cause processing at the very end of the iocRun and iocPause commands
respectively, so RUNNING does occur after both dbCa and rsrv have started.
There is no guarantee that all dbCa links have connected up by then though,
and I've not checked whether the local channels have although I suspect they
might — it probably depends on task priorities so might be different on
vxWorks vs Linux.
> Andrew is correct: I will be between continents next week - probably
> with internet access from Thursday (at the BNL guest house), but in
> vacation busy searching for a place and buying cars until first week of
> August.
Good luck with the move!
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Base Release 3.14.11 Timetable Andrew Johnson
Re: Base Release 3.14.11 Timetable Ralph Lange
Prev: Re: Base Release 3.14.11 Timetable Ralph Lange
Next: Base R3.14.11-pre1 available for testing Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
