2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Base Release 3.14.11 Timetable
Cc: Core-Talk <[email protected]>
Date: Tue, 07 Jul 2009 08:02:34 +0200
only one question (that came up looking at the current status of the 3.14 branch):
I noticed that the codeathon project of adding PINI states has been put into CVS. Is my impression correct, that the original motivation (having a PINI state that allows for PINI processing *after* Channel Access started) somehow disappeared from the radar, and there's still no PINI state with working CA links?
Andrew is correct: I will be between continents next week - probably with internet access from Thursday (at the BNL guest house), but in vacation busy searching for a place and buying cars until first week of August.
Cheers,
Ralph
Andrew Johnson wrote:
I admit this timetable has had little consultation, but I'm extending the normal timing by a week (while I'm in Korea) which I hope will provide some compensation. I suspect Ralph will be switching continents around this time, hopefully others will be able to make up for his absence. The APS needs a release before the end of August...
2009-07-19  All CVS commits must be completed (Sunday evening)
2009-07-20  R3.14.11-pre1 released, testing/debugging commences
2009-08-03  -RC1 vs -pre2 decision and release
2009-08-10  Earliest possible R3.14.11 release date
Do these dates seem reasonable?
- Andrew
Re: Base Release 3.14.11 Timetable Andrew Johnson
Prev: RE: Patch: Move alarm.h and rename alarmString.h Davidsaver, Michael
Next: Re: Base Release 3.14.11 Timetable Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Base Release 3.14.11 Timetable Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
