Ralph
Copyright Motorola Inc. 1999-2003, All Rights Reserved
MOTLoad RTOS Version 2.0, PAL Version 1.1 RM02
Tue Jul 1 16:34:30 MST 2003
MPU-Int Clock Speed =1000MHz
MPU-Ext Clock Speed =133MHz
MPU-Number/Type = 0/MPC7455
MPU-Int Cache(L2) = 256K, Enabled, L2CR =0xC0000000
MPU-Ext Cache(L3) = 2MB, Enabled, 200MHz, L3CR =0xDF826000
Reset/Boot Vector =Flash1
Local Memory Found =20000000 (&536870912)
User Download Buffer =005C3000:007C2FFF
MVME5500> tftpGet -a4000000 -c193.149.12.200 -s193.149.12.29
-g0.0.0.0 -m255.255.255.0 -d/dev/ene
t1 -f/opt/tftpdir/IOC/rtems/rtems-4.9/rtems5500TestHarness.boot
Network Loading from: /dev/enet1
Loading File: /opt/tftpdir/IOC/rtems/rtems-4.9/rtems5500TestHarness.boot
Load Address: 04000000
Client IP Address = 193.149.12.200
Server IP Address = 193.149.12.29
Gateway IP Address = 193.149.12.253
Subnet IP Address Mask = 255.255.255.0
Network File Load in Progress...
Bytes Received =&1109192, Bytes Loaded =&1109192
Bytes/Second =&1109192, Elapsed Time =1 Second(s)
MVME5500> netShut
/dev/enet0 Disabled
/dev/enet1 Disabled
MV-----------------------------------------
Welcome to rtems-4.9.0(PowerPC/Generic (classic FPU)/mvme5500) on
MVME5500-0163
Now BSP_mem_size = 0x1FE00000
rtems_configuration_get_work_space_size() = 1F4000
Universe II PCI-VME bridge detected at 0x82000000, IRQ 12
Universe Master Ports:
Port VME-Addr Size PCI-Adrs Mode:
0: 0x20000000 0x0E000000 0x90000000 A32, D64 [MBLT], Dat, Sup
1: 0x00000000 0x00FF0000 0x9F000000 A24, D64 [MBLT], Dat, Sup
2: 0x00000000 0x00010000 0x9FFF0000 A16, D64, Dat, Sup
Universe Slave Ports:
0: 0x90000000 0x1FE00000 0x00000000 A32, Pgm, Dat, Sup, Usr, PWEN,
PREN
Overriding main IRQ line PCI info with 76
Registering /dev/console as minor 0 (==/dev/ttyS0)
***** Initializing network *****
Startup.
Ethernet driver name wmG unit 1
Copyright (c) 2004,2005 S. Kate Feng <[email protected]> (RTEMS/mvme5500
port)
Can't set default route: Network is unreachable
***** Initializing NFS *****
RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See
LICENSE file for licensing i
nfo.
RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See
LICENSE file for licensing info
Trying to mount 193.149.12.29:/srv/IOC on /srv/IOC
***** Starting EPICS application *****
***** epicsEventTest *****
1..11
ok 1 - epicsEventWaitWithTimeout(event, 0.0) = 1
ok 2 - epicsEventWaitWithTimeout(event, 1.0) = 1
ok 3 - epicsEventTryWait(event) = 1
ok 4 - epicsEventWaitWithTimeout(event, 1.0) = 0
ok 5 - epicsEventWaitWithTimeout(event, DBL_MAX) = 0
ok 6 - epicsEventTryWait(event) = 0
# consumer: starting
# producer 0: starting
# producer 1: starting
# producer 2: starting
# setting quit
ok 7 - consumer: errors = 0
ok 8 - producer 2: errors = 0
ok 9 - producer 0: errors = 0
ok 10 - producer 1: errors = 0
# epicsEventWaitWithTimeout(1.000000) delay error 0.000000 sec
# epicsEventWaitWithTimeout(0.500000) delay error 0.000000 sec
# epicsEventWaitWithTimeout(0.250000) delay error 0.010000 sec
# epicsEventWaitWithTimeout(0.125000) delay error 0.005000 sec
# epicsEventWaitWithTimeout(0.062500) delay error 0.002500 sec
# epicsEventWaitWithTimeout(0.031250) delay error 0.011250 sec
# epicsEventWaitWithTimeout(0.015625) delay error 0.004375 sec
# epicsEventWaitWithTimeout(0.007812) delay error 0.012188 sec
# epicsEventWaitWithTimeout(0.003906) delay error 0.016094 sec
# epicsEventWaitWithTimeout(0.001953) delay error 0.018047 sec
# epicsEventWaitWithTimeout(0.000977) delay error 0.019023 sec
# epicsEventWaitWithTimeout(0.000488) delay error 0.019512 sec
# epicsEventWaitWithTimeout(0.000244) delay error 0.019756 sec
# epicsEventWaitWithTimeout(0.000122) delay error 0.019878 sec
# epicsEventWaitWithTimeout(0.000061) delay error 0.019939 sec
# epicsEventWaitWithTimeout(0.000031) delay error 0.019969 sec
# epicsEventWaitWithTimeout(0.000015) delay error 0.019985 sec
# epicsEventWaitWithTimeout(0.000008) delay error 0.019992 sec
# epicsEventWaitWithTimeout(0.000004) delay error 0.019996 sec
# epicsEventWaitWithTimeout(0.000002) delay error 0.019998 sec
# epicsEventWaitWithTimeout(0.000000) delay error 0.000000 sec
ok 11 - Average error 0.013214 sec
Results
Tests: 11
Passed: 11 = 100.00%
In BSP_exceptionHandler()
Uhuuuh, Exception 10 in unknown task???
Next PC or Address of fault = C4A08, Mvme5500 Saved MSR = B032
R0 = 00000AE0 R1 = 1FC27B10 R2 = 00000000 R3 = 001AC778
R4 = 001075DC R5 = 000A2864 R6 = 00110000 R7 = 000AA6B4
R8 = 001AC748 R9 = 474E5543 R10 = 432B2B00 R11 = 0010EC60
R12 = 24400022 R13 = 001164D0 R14 = 00000000 R15 = 00000000
R16 = 00000000 R17 = 00000000 R18 = 00000000 R19 = 00000000
R20 = 00000000 R21 = 1FC288C8 R22 = 1FC288F0 R23 = 000EA970
R24 = 000EA9E4 R25 = 1FC28914 R26 = 00122870 R27 = 0000D45C
R28 = 00000023 R29 = 001AC778 R30 = 00114B14 R31 = FFFFFFFF
CR = 24400022
CTR = 00000000
XER = 00000000
LR = 000A237C
DAR = 00000000
Stack Trace:
IP: 0x000C4A08, LR: 0x000A237C
--^ 0x000A237C--^ 0x000A29F8--^ 0x000A2A18--^ 0x0000D208--^ 0x0000D47C
--^ 0x0001831C--^ 0x000104B0--^ 0x0000330C--^ 0x0002A6AC--^ 0x00067330
--^ 0x000672B0
unrecoverable exception!!! task 0A010001 suspended
***** epicsExceptionTest *****
1..4
