2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: 3.14.10 on native win32: make problem
Cc: [email protected]
Date: Fri, 24 Apr 2009 10:51:42 +0200
Thanks Andrew,
instead of the README I was only reading the RULES_DIRS file itself which says (at the beginning of the block that produces the error)
   # Only works with GNU make 3.80 or later (uses eval function)
So I thought I was fine - but I wasn' t.
Cheers,
Ralph
On 23.04.2009 17:11 Andrew Johnson wrote:
Hi Ralph,
On Thursday 23 April 2009 09:45:05 Ralph Lange wrote:
I'm trying to compile 3.14.10 on a native (non-cygwin) WinXP SP3 using
VisualC++ 2005 Express / Windows 2003 Server SDK R2 and mingw GNU make
3.80.
^^^^ There's your problem, you need 3.81 minimum for R3.14.10 (see README file). It is available for mingw:
C:\epics\base3-14>make --version
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i686-pc-mingw32
HTH,
- Andrew
3.14.10 on native win32: make problem Ralph Lange
Re: 3.14.10 on native win32: make problem Andrew Johnson
Prev: Re: 3.14.10 on native win32: make problem Andrew Johnson
Next: Re: Failing EPICS Test Harness on RTEMS-mvme5500 Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: some field definitions Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
