Ernest L. Williams Jr. wrote:
There is already a patch listed in the "Known Problems" section for the
R3.14.8 release. Does the patch make it R3.14.8.1 or is there more?
There are also some Win32 changes to do with exported symbols that are
needed for Asyn.
Well, I think that a 4th revision number is okay to describe a patch.
What does each number represent in your current definition of the
Revision numbering scheme?
From the current configure/CONFIG_BASE_VERSION:
EPICS_VERSION=3
EPICS_REVISION=14
EPICS_MODIFICATION=8
EPICS_UPDATE_NAME=
EPICS_UPDATE_LEVEL=0
The variable names are not particularly meaningful, and the two UPDATE
items may be about to be replaced with something else.
EPICS_VERSION used to mean the version of the CA protocol; different
versions were not expected to be able to talk to each other.
EPICS_REVISION increases indicates a significant change in features
and/or functionality, and may require significant effort to upgrade IOCS
and/or support applications (3.13 to 3.14). EPICS_MODIFICATION
increments indicate minor enhancements to features and APIs, and
incorporation of bug fixes.
EPICS_UPDATE_NAME were originally designed for the words 'alpha'/'beta'
and EPICS_UPDATE_LEVEL for the alpha/beta version number. We'd like to
replace these two with a new EPICS_PATCH_LEVEL variable, and add a
variable EPICS_CVS_SNAPSHOT that distinguishes between official releases
and CVS snapshots. Between official releases, the version numbers would
look like 3.14.8-CVS.
We're also adding an EPICS_SITE_VERSION string in configure/CONFIG_SITE
that allows sites to easily append their own version information to the
EPICS version string - if set this will be appended after the -CVS.
This is most of the new CONFIG_BASE_VERSION file:
EPICS_VERSION = 3
EPICS_REVISION = 14
# This part may contain letters, eg 0beta1
EPICS_MODIFICATION = 8
# Not included if zero
EPICS_PATCH_LEVEL = 0
# This must be -CVS or (during an official release) blank
EPICS_CVS_SNAPSHOT=-CVS
# No changes should be needed below here
ifneq ($(EPICS_PATCH_LEVEL),0)
EPICS_PATCH_VSTRING=.$(EPICS_PATCH_LEVEL)
endif
ifneq ($(strip $(EPICS_SITE_VERSION)),)
EPICS_SITE_VSTRING=-$(EPICS_SITE_VERSION)
endif
EPICS_SHORT_VERSION=$(EPICS_VERSION).$(EPICS_REVISION).$(EPICS_MODIFICATION)$(EPICS_PATCH_VSTRING)
EPICS_VERSION_NUMBER=$(EPICS_SHORT_VERSION)$(EPICS_CVS_SNAPSHOT)$(EPICS_SITE_VSTRING)
EPICS_VERSION_STRING="EPICS Version $(EPICS_VERSION_NUMBER)"
Ralph:
Your local definitions for UPDATE_NAME and UPDATE_LEVEL would be
combined into EPICS_SITE_VERSION in the CONFIG_SITE file. Is the above
likely to be sufficient for BESSY's needs? Thanks for pointing out the
additional uses of those var's BTW.
Looking at the HPUX addition to SHRLIB_SEARCH_FULLPATHDIRS in the
os/CONFIG_SITE.Common.hpux-parisc file, I think you could do this an
easier way: If you add an entry to your base/configure/RELEASE file
pointing to the /opt/... install location top, and ensure that there is
actually a lib/hpux-parisc directory present before you build base, then
that lib directory will get added to SHRLIB_SEARCH_DIRS inside base's
auto-generated CONFIG_APP_INCLUDE file. I'm not sure whether you'd need
that RELEASE file entry just in base, or in your support modules too -
that depends whether the definition of EPICS_BASE in the support modules
points to the development location or to the /opt/... install directory.
Overall I suspect this would be a cleaner way to get your install
directory into the runtime search path as it puts the site-specific path
into the RELEASE file.
I've just committed this change to CVS but haven't touched the hpux
stuff, if you have time please have a look and work out how you want to
play this.
- Andrew
* * Matt Santos / / Leo McGarry * * For a Brighter America * *
- Re: Revision numbers Ernest L. Williams Jr.
- Revision numbers Andrew Johnson
Re: Revision numbers Ralph Lange
<2005>
<2005>
