2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Revision numbers
Cc: Janet Anderson <[email protected]>
Date: Thu, 15 Dec 2005 22:55:31 +0100
We have been using the fourth digit to number our own in-house patches. This seemed the intended way, as .../configure/CONFIG_BASE_VERSION calls the fourth tag UPDATE_NAME and UPDATE_LEVEL, assuming these are site-specific to create things like 3.14.8.aps1 3.14.8.aps2 etc.
I would see an official 3.14.8.1 breaking the official numbering concept, but for BESSY I could adapt to a fourth "official" number by adding a fifth one. Well - actually you should introduce a new intermediate level in CONFIG_BASE_VERSION, leaving the old tags for UPDATE_NAME and UPDATE_LEVEL intact. Please remember to update all files under .../configure that use the definitions from CONFIG_BASE_VERSION, otherwise shared library search paths will be wrong (again), at least for HP-UX.
Ralph
(just came in for a night shift - sorry for the delay)
Andrew Johnson wrote:
We need to make a new release with the latest bug fixes incorporated. The majority view (not unanimous though) here at APS is that we should call this R3.14.8.1 rather than R3.14.9 since it really is just a patch release with no new functionality included. If this numbering is likely to cause any problems please reply ASAP, as otherwise this might happen later today.
- Andrew
Revision numbers Andrew Johnson
Prev: Re: Revision numbers Ernest L. Williams Jr.
Next: Re: Revision numbers Andrew Johnson
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: VDCT expand and template constructs Rees, NP (Nick)
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
