-----Original Message-----
Sent: Tuesday, November 29, 2005 10:13 AM
To: 'Ralph Lange'
Cc: Janet Anderson ([email protected]); Andrew Johnson ([email protected])
Subject: ms and setvbuf
I resolved mantis 230.
I had a closer look at the MS and the POSIX doc. It appears that there is
confusion between the two related to how the setvbuf arguments will be
interpreted if the user buffer pointer is null. In the POSIX doc it clearly
states that the count only applies if the user pointer isn't nill. In the MS
doc it clearly states that the count is also the size of the internally
allocated buffer when the user pointer is nill. This explains, after sending
your brain to Redmond WA for a lobotomy, why there is an assert fail in
setvbuf if the buffer size is zero.
It seems that a reasonable compromise will be to specify a buffer size of
BUFSIZ (defined by POSIX and fortunately also by windows).
I committed that change.
Jeff
__________________________________________________________
Jeffrey O. Hill Mail [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA Fax 505 665 5107
Re: R3.14.8 makeBaseApp.pl - File::Find problem on cygwin Ralph Lange
release notes update Jeff Hill
<2005>
Re: R3.14.8 makeBaseApp.pl - File::Find problem on cygwin Andrew Johnson
<2005>
