Ralph Lange wrote:
so - as makeBaseApp's use of find() follows exactly the third form
mentioned in the synopsis - what you're saying is: On cygwin File::Find
does not work as documented.
Janet looked at this, and discovered that the find() only works if we
give it a starting path in the form d:\path\to\dir whereas
makeBaseApp.pl was giving it /cygdrive/d/path/to/dir -- there's probably
something inside cygwin that makes the /cygdrive/ path a link that isn't
followed, or something equally wierd.
We've added another function LocalPath() which does the reverse
conversion that UnixPath() does, and the resulting makeBaseApp.pl now
works properly on Windows. However there's a parallel problem with the
definition of TOP in the generated iocBoot/iocXxx/envPaths file when
built on the Borland target (the borland stuff is more picky when it
comes to paths), so I'm looking at installing a similar path mangling
function into convertRelease.pl which we'll test tomorrow.
To quote a comment in makeBaseApp.pl: Bl**dy Windows stupidity...
- Andrew
* * Matt Santos / / Leo McGarry * * For a Brighter America * *
- RE: [Fwd: RE: R3.14.8 makeBaseApp.pl] Jeff Hill
- Re: R3.14.8 makeBaseApp.pl - File::Find problem on cygwin Ralph Lange
Re: main trunk build failure on win32 Andrew Johnson
appDevGuide Marty Kraimer
<2005>
FW: ms and setvbuf Jeff Hill
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
