2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CA V4 Protocol Specification
To: [email protected]
Date: Wed, 26 Oct 2005 06:55:31 -0500
Benjamin Franksen wrote:
On Wednesday 26 October 2005 00:33, Jeff Hill wrote:
Attached is a rough cut at the EPICS V4 CA protocol specification.
Hi Jeff,
Just one little thought about STRING data type:
UINTN			the number of UTF-8 tokens
OCTET sequence	UTF-8 encoded character string sequence
I take it that 'number of UTF-8 tokens' means 'number of octets', right? Maybe it would be worthwhile to consider adding a 'number of /characters/' count in addition to the byte count. This could improve performance, particularly when converting to other encodings on the client side. Of course any gain must be offset against the increased protocol overhead.
The same applies of course to any library string representations.
Ben
Java 5 uses 16 bits for char, which is not sufficient to encode all uni-code character sets. It uses 2 consecutive chars to hold a unicode character that does not fit in 16 bits.
At least some C/C++ implementations use 32 bits for wchar which is sufficient for all unicode characters.
But what if an implementation uses 16 bits?
Thus how will the number of characters in a UTF-8 string be used?
Better to just let final sender/receiver of the character string handle it.
Marty
Re: CA V4 Protocol Specification Andrew Johnson
CA V4 Protocol Specification Jeff Hill
Re: CA V4 Protocol Specification Benjamin Franksen
Prev: Re: Release 3.14.8: What goes in it and when? Marty Kraimer
Next: Re: Release 3.14.8: What goes in it and when? Marty Kraimer
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CA V4 Protocol Specification Benjamin Franksen
Next: Re: CA V4 Protocol Specification Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
