EPICS Channel Access Protocol Specification
EPICS Version: 4
Channel Access Protocol Version: 4.15
Author: Jeff Hill
LA-UR-05-8238
Data Types
- All multi-octet primitive types are transmitted in little endian byte
order.
- All signed integers use two's complement arithmetic.
- All floating point numbers shall comply with IEEE floating point
standards.
Externally Visible Data Types
Mnemonic |
Data Type |
Identifier |
reserved |
0 |
INT8 |
8 bit signed integer |
1 |
INT16 |
16 bit signed integer |
2 |
INT32 |
32 bit signed integer |
3 |
INT64 |
64 bit signed integer |
4 |
FLOAT32 |
32 bit IEEE floating point |
5 |
FLOAT64 |
64 bit IEEE floating point |
6 |
FLOAT128 |
128 bit IEEE floating point |
7 |
STRING |
UTF-8 encoded character string |
8 |
PSD |
property sequence description |
9 |
reserved |
10 - 128 |
Protocol Private Data Types
Mnemonic |
Data Type |
UINT8 |
8 bit unsigned integer |
UNIT16 |
16 bit unsigned integer |
UINT32 |
32 bit unsigned integer |
UINT64 |
64 bit unsigned integer |
UINTN |
variable length unsigned integer |
PTD |
property transport definition |
DSD |
dimension sequence description |
DBD |
dimension bounds definition |
ADB |
array dimension bound |
The octets below are in little endian order (least significant bits are
transmitted before most significant bits).
UINTN - 1 octet
Data Type |
Bit 7, msb |
Bits 7 - 0 |
OCTET |
0 |
Bits 0-7 of unsigned integer value |
UINTN - 2 octets
Data Type |
Bit 7, msb |
Bits 7 - 0 |
OCTET |
1 |
OCTET |
0 |
Bits 8-15 of unsigned integer value |
UINTN - 3 octets
Data Type |
Bit 7, msb |
Bits 7 - 0 |
OCTET |
1 |
OCTET |
1 |
OCTET |
0 |
Bits 16-23 of unsigned integer value |
After 3 octets, the same pattern repeats.
UINTN - N octets
Data Type |
msb |
Bits 7 - 0 |
OCTET |
1 |
OCTET |
1 |
OCTET |
1 |
1 |
OCTET N |
0 |
Bits N*8-N*9-1 of unsigned integer value |
STRING
Data Type |
Purpose |
UINTN |
the number of UTF-8 tokens |
OCTET sequence |
UTF-8 encoded character string sequence |
Nill (zero) termination is not included in the string.
This data type is used to describe a packed sequence of property values, a
property sequence (PS), that might be encapsulated within a subsequent
message on the same circuit, or in the same datagram. The order that the
properties are described in the sequence is exactly the same as the order
that the properties will be pushed onto the wire.
Container Property Transport Sequence Description
Data Type |
Purpose |
UINTN |
Number of properties in sequence |
N Property transport definitions |
See below |
If the dimension field is zero then property bounds
definitions are not included, and the property transported has a scalar
representation.
Property Transport Definition - Atomic
Data Type |
Purpose |
Value |
UINTN |
Property Id |
Sender defined |
UINTN |
Data Type Identifier |
Sender defined, not 9 |
DSD |
Dimension sequence description |
Sender defined |
Property Transport Definition - Container
Data Type |
Purpose |
Value |
UINTN |
Property Id |
Sender defined |
UINTN |
9 |
DSD |
Sender defined |
PSD |
Property sequence description |
Sender defined |
Scalar Dimension Sequence
Data Type |
Purpose |
Value |
UINTN |
Specifies that the data is scalar |
0 |
Array Dimension Sequence
Data Type |
Purpose |
Value |
UINTN |
Specifies the number of property bounds definitions for array
data |
N, not zero |
N X DBD |
sequence of N property bounds definitions |
Sender defined |
Property Bounds Definition, Fixed Bound
Data Type |
Purpose |
Value |
UINTN |
Bound Type |
0, fixed bound |
ADB |
Array dimension bound |
Sender defined |
Property Bounds Definition, Variable Bound
Data Type |
Purpose |
Value |
UINTN |
Bound Type |
1, variable bound |
Packaging of arrays on the wire
If the bound type is fixed, then the dimension does not accompany the
array data on the wire. If the bound type is variable then any variable
dimension information immediately precedes the data on the wire. The order
that any dynamic dimensions are described in the dimension sequence
description (DSD) is exactly the same order that any dynamic array dimension
bound (ADB) will be pushed on to the wire prior to pushing the array data
sequence on to the wire.
Array Dimension Bound
Data Type |
Purpose |
Value |
UINTN |
First element index |
Sender defined |
UINTN |
Element count |
Sender defined |
Property Hierarchy Path
<property hierarchy path> := <optional white space> .
<optional white space> <property name> <optional white
space> [ <property hierarchy path> ]
A "." character is employed to separate components of the property
hierarchy path. Should the user need to include the "." in a channel name,
they can escape the "." character with a back slash "\" character.
Channel
A channel is defined to be a virtual communication path from a client
application to a communication receptacle in a service. The communication
receptacle is either a process variable or a message passing interface.
Channel Names
Flat (hierarchy challenged) tools like caGet will need to access a
property deeply embedded in the property hierarchy as a simple PV.
Therefore, channel names will have the following format.
<communication receptacle name> [ <property hierarchy path>
This syntax may
clash with the current state of the version 4 database design.
Message Transport
The protocol is designed for transport via a full duplex octet stream
circuit such as is offered by TCP/IP. Clients initiate circuits with servers.
All clients and servers initiating a new outgoing octet stream circuit
must insert, prior to any other message, a CA Protocol
Initiate message. Certain requests (see documentation for each
request) will also be suitable for datagram transport such as is offered by
UDP/IP. The CA Protocol Initiate message must be the
first message in any CA protocol datagram prior to any other message in the
datagram.
The protocol is asynchronous, and therefore multiple requests can be
outstanding (waiting for a response) at the same time. It is expected that
quality implementations will combine several messages together into one
network frame.
This message overlays a similar purposed message employed by previous
versions of the protocol thereby retaining potential for client and server
libraries to, at runtime, choose between dispatch tables suitable to
different protocol revisions. This allows client and server libraries to
communicate with multiple peers using both the EPICS version 3 and the EPICS
version 4 protocols.
There is no response to this message.
Data Type |
Purpose |
Value |
UINT16 |
reserved |
0 |
UINT16 |
reserved |
0 |
UINT16 |
requested server dispatch priority where 0 is the lowest priority
(executes last) and 255 is the highest priority (executes first), all
other values are reserved |
clients |
servers |
0 - 255 |
0 |
UINT16 |
protocol minor revision number |
15 |
UINT32 |
magic number |
0x5b43415d == '[' 'C' 'A' ']' |
UNIT32 |
Reserved for virtual circuits.
A sequence number incrementing with each successive message for
datagrams. Clients use this sequence number to detect duplicates and
out of order delivery.
circuit |
datagram |
0 |
sequence number |
The dispatch priority protocol element is relevant only when a client
initiates communication with a server. Servers do not request a dispatch
priority within its client, and should set this field to zero.
Request / Response Protocol
Request Messages
Request messages are transmitted only by clients. Servers do not transmit
request messages. There are two request message forms depending on whether a
response is possible, or not.
Request Message - Response is Possible
Data Type |
Purpose |
Value |
UINTN |
Request identifier |
client defined |
OBJID |
client defined, 0 - 31 reserved |
OCTETS |
Request payload |
request dependent |
Request Message - No Response
Data Type |
Purpose |
Value |
UINTN |
client defined |
OCTETS |
Request payload |
request dependent |
Response Messages
Response messages are transmitted only by servers. Clients do not transmit
response messages.
Solicited Response Messages
Success Response
Data Type |
Purpose |
Value |
UINTN |
request identifier |
request defined |
OCTETS |
response payload |
request dependent |
Unsolicited, or Indirectly Solicited, Response Messages
Exception Response
This indirectly solicited response is sent when a request fails in the
server.
Exception Response
Data Type |
Purpose |
Value |
UINTN |
0 |
UINTN |
Exception identifier |
failure dependent, see below |
STRING |
Failure context message |
failure dependent |
UINTN |
Copy of request message length |
N, request defined, but zero if failure not caused by a request |
N OCTETS |
Copy of request message |
request defined |
Exception Identifier
Status Value |
Definition |
Severity |
0 |
Insufficient memory to complete request |
Warning |
1 |
Invalid request identifier |
Fatal |
2 |
Invalid channel name |
Warning |
3 |
Invalid channel identifier |
Fatal |
4 |
Invalid property identifier |
Fatal |
5 |
Invalid property transport sequence identifier |
Fatal |
Server Status Beacon
This request is sent by a server to announce periodically its presence,
and availability, on the network. This request might be sent over a virtual
circuit, or in a datagram. There is no response. The property transport
sequence might be predefined at compile time. It is used to identify the
server address (including possibly a TCP port) of the sender, and other
(possibly site specific) server state variables.
Data Type |
Purpose |
Value |
UINTN |
1 |
UINTN |
Property sequence identifier |
Sender Defined |
PS |
Server status parameters |
Sender Defined |
Protocol Encapsulation
Data Type |
Purpose |
Value |
UINTN |
Directive |
0 |
UINTN |
Encoding |
TBD, but to include an unmodified encoding and at least one
standard type of compression encoding |
UINTN |
Length |
N, compressed protocol sequence length |
N OCTETS |
Encapsulated protocol octet sequence |
Sender defined, format determined by encoding |
The maximum size of an encapsulation probably needs to be specified.
Compression will be useful only when fast computers communicate or
relatively slow links.
Define Channel
The client defines a channel in the server for its future use. There is no
response unless the request is invalid, or cant be completed.
If at any time a communication endpoint to which a channel is bound ceases
to exist, the server must send an Invalid channel identifier
exception responses to all of the appropriate clients indicating that their
channel is attached to a defunct resource. After receiving the Invalid
channel identifier exception the client library is no-longer required
to close the relevant channel with the server.
Define Channel Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
1 |
UINTN |
Channel Identifier |
Sender defined |
STRING |
Channel Name |
Sender defined |
Expunge Channel
The client must expunge any channel from the server that will no-longer be
used.
Expunge Channel Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
UINTN |
Sender defined |
Swap Channel Identifiers
Commands the server to assign the process variable associated with channel
identifier one to channel underived two and visa-versa. This functionality
allows implementation to dynamically adjust frequently used objects to use
smaller integer identifiers, and therefore smaller on-the-wire
representations.
Swap Channel Identifiers Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
UINTN |
Sender defined |
UINTN |
Channel Identifier one |
Sender defined |
UINTN |
Channel Identifier two |
Sender defined |
Swap Channel Identifiers Successful Response
Data Type |
Purpose |
Value |
UINTN |
Client defined |
Define Property
The client defines a property in the server for its future use. There is
no response unless the request is invalid, or cant be completed. Commonly
used properties, especially those used by datagram services, will be
predefined thereby avoiding any need to define the property before it is
used.
Define Property Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
2 |
UINTN |
Property identifier |
Sender defined |
STRING |
Property name |
Sender defined |
Expunge Property
The client must expunge any property from the server that will no-longer
be used.
Expunge Property Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
UINTN |
Property Identifier |
Sender defined |
Swap Property Identifiers
Commands the server to assign the property associated with property
identifier one to property underived two and visa-versa. This functionality
representations.
Swap Property Identifiers Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
UINTN |
Sender defined |
UINTN |
Property Identifier one |
Sender defined |
UINTN |
Property Identifier two |
Sender defined |
Swap Property Identifiers Successful Response
Data Type |
Purpose |
Value |
UINTN |
Client defined |
Define Property Transport Sequence
The client defines a property transport sequence in the server for its
future use. A property transport sequence exactly describes a stream of
octets that will express a sequence of properties in the primitive type and
dimension selected by the client. There is no response unless the request is
Commonly used
property transport sequences, especially those used by datagram services,
might be predefined thereby avoiding any need to define the property
transport sequence before it is used.
Define Property Transport Sequence Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
3 |
UINTN |
Sender defined |
PSD |
Property sequence description, see above |
Sender defined |
Expunge Property Transport Sequence
The client must expunge any property transport sequence from the server
that will no-longer be used.
Expunge Property Transport Sequence Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
UINTN |
Property Transport Sequence Identifier |
Sender defined |
Swap Property Transport Sequence Identifiers
Commands the server to assign the property transport sequence associated
with property identifier one to property transport sequence identifier two
and visa-versa. This functionality allows implementmplementation to
dynamically adjust frequently used objects to use smaller integer
identifiers, and therefore smaller on-the-wire representations.
Data Type |
Purpose |
Value |
UINTN |
Directive |
UINTN |
Sender defined |
UINTN |
Property Transport Sequence Identifier one |
Sender defined |
UINTN |
Property Transport Sequence Identifier two |
Sender defined |
Swap Property Transport Sequence Identifiers Successful
Response
Data Type |
Purpose |
Value |
UINTN |
Client defined |
Define IO Request Modifier
Define an IO request modifier. There is no response unless the request is
The client must cancel any request trigger specification in the
server that will no-longer be used.
Define Request Trigger Specification Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
4 |
UINTN |
IO request modifier identifier |
Sender defined, see below |
STRING |
<IO Request Modifier _expression_> |
Value |
Purpose |
0 |
IO Type |
Synchronization Type |
write |
unsynchronized write |
read |
unsynchronized read |
command |
unsynchronized command |
subscribe |
first update is an unsynchronized read followed by updates
for every state change |
1 - 32 |
reserved |
N > 32 |
client library assigned |
<IO Request Modifier _expression_> :=
<Property Match _expression_> <IO Request Attribute List>
<Property Match _expression_> :=
[(] [ [<Property Match _expression_>] <Boolean Operator> ] <Property Match Specification> [)]
<IO Request Attribute List> :=
<IO Request Attribute> [ <IO Request Attribute List> ]
<IO Request Attribute> :=
<Subscription Modifier>,
<Minimum Period Spec>,
<Maximum Period Spec>,
<Minimum Percent Change Between Updates Spec>,
<Time Based Extraction Criteria>,
<Maximum Event Queue Length>,
<Trigger Time Offset>,
<Property Path>
<Property Name> <Comparison Operator>
{ <Property Name>, <Channel Name>, <Constant _expression_> }
Here are some examples of IO modifier expressions. Parenthesis may be used
to enforce order of operations.
(beamGate == 4 ) && ! ( bpm32.beamGate == 7)
beamGate == 4 && triggerTimeOffset ( 3 sec )
beamGate == 4 && eventQueueLength ( 1 ) maxPeriod ( 4 sec )
eventQueueLength ( 1 ) propertyPath ( limits )
eventQueueLength ( 1 ) propertyPath ( xAxisMotor.limits )
Minimum and Maximum Period (applicable only to subscriptions)
timeSpec := <real number> <time units>
maxPeriod ( timeSpec )
minPeriod ( timeSpec )
Minimum Percent Change Between Updates (applicable only to
subscriptions)
minPercentChange ( <real number> )
Time Based Extraction Criteria (applicable only to subscriptions)
beginTime ( timeSpec )
endTime ( timeSpec )
Maximum Event Queue Length (applicable only to subscriptions)
eventQueueLength ( <integer number> )
Trigger Time Offset (applicable only to subscriptions)
triggerTimeOffset ( timeSpec )
Property Path
propertyPath ( <property hierarchy path> )
Attributes controlling queueing versus caching behavior of read and writes are probably specified here. Needs more thought.
Attributes controlling process passive and maximize severity (or their future functional equivalents) are probably specified here. Needs more thought.
Expunge IO Request Modifier
The client must expunge any IO request modifier from the server that will
no-longer be used.
Data Type |
Purpose |
Value |
UINTN |
Directive |
UINTN |
Sender defined |
Swap IO Request Modifier Identifiers
Commands the server to assign the trigger specification associated with
property identifier one to trigger intensifier two and visa-versa. This
functionality allows implementation to dynamically adjust frequently used
objects to use smaller integer identifiers, and therefore smaller on-the-wire
representations.
Data Type |
Purpose |
Value |
UINTN |
Directive |
UINTN |
Sender defined |
UINTN |
IO request modifier identifier one |
Sender defined |
UINTN |
IO request modifier identifier two |
Sender defined |
Swap Trigger Identifiers Successful Response
Data Type |
Purpose |
Value |
UINTN |
Client defined |
Channel Write Without Response
The client writes a property transport sequence to a process variable in
the service. There is no response unless the request is invalid, or cant be
completed.
Channel Write Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
5 |
UNINT |
Channel identifier |
Sender defined |
UINTN |
Property sequence identifier of payload |
Sender defined |
UINTN |
Sender defined |
PS |
Property payload to be written |
Sender defined |
Channel Write With Response
the service. There is always a response. A successful response indicates that
the request, and all side effects, have completed. An unsuccessful response
is an exception response (see above). It indicates that the request could not
be completed in entirety, and that the internal state of the channel has not
been modified.
Data Type |
Purpose |
Value |
UINTN |
Directive |
6 |
UINTN |
Sender defined |
UINTN |
Sender defined |
UINTN |
Sender defined |
UINTN |
Sender defined |
PS |
Sender defined |
Channel Write Successful Response
Data Type |
Purpose |
Value |
UINTN |
Client defined |
Channel Read or Subscribe
The client reads a property transport sequence from a process variable in
the service. If the request identifier is 7, there is only one response.
Otherwise, if the request identifier is 8, a subscription is created and
multiple responses are expected. A successful response includes the specified
property transport sequence identifying the current state of the channel when
the request was executed by the server. An unsuccessful response is an
Channel Read or Subscribe Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
7 or 8 |
UINTN |
Sender defined |
UINTN |
Sender defined |
UINTN |
Property sequence identifier of response payload |
Sender defined |
UINTN |
Sender defined |
Channel Read or Subscribe Successful Response
Data Type |
Purpose |
Value |
UINTN |
Client defined |
PS |
Property payload read |
Client formatted, server defined |
Channel Command
The client sends a command to a message passing interface in the service.
A request in the form of a property transport sequence is sent to the message
passing interface in the service, and the message passing interface responds
with another property transport sequence.
Data Type |
Purpose |
Value |
UINTN |
Directive |
9 |
UINTN |
Sender defined |
UINTN |
Sender defined |
UINTN |
Request property sequence payload identifier |
Sender defined |
UINTN |
Response property sequence payload identifier |
Sender defined |
UINTN |
Sender defined |
PS |
Request property payload |
Sender defined |
Data Type |
Purpose |
Value |
UINTN |
Client defined |
PS |
Response property payload |
Cancel Request
Cancel a request in progress. There is no response.
Cancel Previous Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
10 |
UINTN |
identifier of the request to be canceled |
Server Verify
Verify that the server is responsive.
This request might also be accepted to by a datagram server. Typically, a
response is mandatory, but a datagram server must never respond to
any request of this type in a datagram sent to a broadcast or multicast
address.
The property transport sequence is used to identify the condition of the
server, and other (possibly site specific) server state variables.
Server Verify Request
Data Type |
Purpose |
Value |
UINTN |
Directive |
11 |
UINTN |
Sender defined |
UINTN |
Sender defined |
Circuit Verify Successful Response
Data Type |
Purpose |
Value |
OBJID |
Client defined |
PS |
Design Notes
- A fundamental choice of this design was that all identifiers are
assigned by the client. This tends to make state change logic simpler in
the client library and, since the server's identifier need not be
returned in a response to the client, there will also be less TCP return
pipe traffic during setup.
The server might continue to have only one hash table keyed by an
{object id, client id} pair. Hopefully, the bucket use distribution for
this table can be managed to be reasonably uniform. This type of keying
probably slightly increases hashing and distribution overhead so,
alternatively, there could be one hash table in the server for each
client, contingent possibly on upgraded memory management for the hash
table implementation.
There is a chance that a request to define a channel will be sent to a
server that does not have the named communication receptacle. In that
situation the server will send the client an exception, and respond to
any subsequent requests specifying a bogus channel identifier with an
exception message.
The unfortunate drawback to this approach will be the opportunity for
a client to briefly think that it is connected when it isn't. We are
currently ensuring that disconnect notification arrives within NNN
seconds so perhaps brief windows of uncertainty are not unreasonable.
Also, this window of uncertainty would exist prior to arrival of the
first monitor update so any client that watches the magnitude of a
channel should remain in a safe state.
- The flow-control functionality in previous versions of the CA protocol
was probably only relevant to GUI applications. It is superseded in this
version of the protocol by capabilities allowing clients to set the
subscription event queue length?
- Server beacons are used to efficiently inform multiple clients about
server state of health while using minimum bandwidth.
Multicasts/broadcasts are typically the lowest bandwidth consuming option
when sending one message to multiple clients. Server beacons are used to
A) inform clients when a newly accessible IOC joins the network, and B)
periodically communicate tangible indication of responsiveness to clients
with idle TCP circuits.
In this version of the protocol hopefully beacons will be issued using
multicast addresses thereby eliminating any need for the CA Repeater
daemon.
In this version of the protocol additional server state of health
properties might be included in the beacon message.
- The current baseline is to not include messages in the CA protocol for
authentication purposes. Instead, we prefer to use transport protocol
facilities for coarse host based authentication, and integrate public
domain kerberos libraries (or some other equivalent) for stronger forms
of authentication including user based authentication.
- The current baseline is to employ subordinate properties to communicate
the current state of the access rights for a channel.
Will access rights properties need to show up in multiple places in
the property hierarchy in order that the access rights might vary
depending on what properties are accessed? If so, then how can we provide
a consistent interface for clients so that they always know where to find
the access rights in the property hierarchy?
- Users will need to monitor the connection state of channels.
Within the protocol there is a channel disconnect exception
designating a service disconnect. There might also be a transport circuit
disconnect.
The user will probably subscribe at the client programming interface
for connection state change callbacks using the subscription mechanism.
The client library will trap the appropriate exceptions and circuit
disconnect state changes forwarding them as synthesized subscription
update callbacks at the programming interface.
- The queueing versus caching behavior of write request sent to a channel
will be modified by specifying a specialized IO request modifier with the
write request.
- The EPICS function block database's process passive and maximize
severity link attributes (or their future equivalents) will be
manipulated by specifying a specialized IO request modifier.
- It will be necessary to introspect all of (or a subset of) the
properties that are available in a channel. This will be accomplished by
reading the
propertyList property of the channel and
requesting primitive type PSD or STRING .
- There will be situations where the client will prefer to create one
channel, but index any part of the property hierarchy. This will be done
by specifying the property path in a relevant IO request modifier.
- It will probably also be necessary to obtain a list of all of the
communication receptacles in a server. This might be accomplished by
sending a request / response command to a specialized PV. Wild cards
could be specified in the request parameters and the channel list could
be delivered in the response parameters.
- Within future EPICS systems a special property accompanying state
change update notification payloads must efficiently indicate the type of
state change that has occurred. For example, there are currently "default
dead-band state change excursion", "archive dead-band state change
excursion", and "alarm state change" state change identifying events.
This information will be needed, for example, to improve the
implementation of the CA gateway. Starting with version four of EPICS a
PSD will define a special type for communicating this information, and a
standard property name will be assigned for locating this information in
a subscription update payload. This property will also be used in IO
request modifiers to filter out state changes that might not be needed.
