g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Subject: V4 Data Types: Request for tagged unions
To: EPICS Core Talk <core-talk@aps.anl.gov>
Date: Wed, 15 Jun 2005 16:20:00 +0200
As a result of intensive (almost excessive) discussions of today, I would like to spit out a requirement for:
 Tagged unions as a basic V4 data type
Let me give one example based on the idea of implementing Sequencer state sets as (pseudo) record instances: The sequences will (hopefully) be able to support parametrized states, i.e. instead of changing global variables and plainly switching to another state, you can switch to the new state handing in some parameters. If the current state of a state set is to be represented by a (pseudo) field of the state set's (pseudo) record, that field's data has the form of a tagged union, i.e. it is organized like:
state = init     state = start     state = wait
  int i1           double d;         char t1;
  int i2           int j1;           int j3;
                   int j2;
Such a field can transparently contain the complete state information, including any parameters for that state.
Structures (such as the parameter list) are represented by C structures internally and property catalogs externally (through DA).
The state tag is represented as an enum (both internally and externally).
The DA representation of the tagged union would be a property catalog that consists of the tag (which is an enum) and the properties that can vary in type, name and number depending on the tag's value.
Access can be managed by generating DA code that:
- find()s only properties that are present - depending on the tag value
- traverse()s always the tag first, then the matching properties, both for the reading and writing traversals
The only place where DA has to be extended is for the new method (under construction) that traverses the property names and natural types. For that special traversal, the tagged union is very much like an enum, but with an additional property catalog connected to each of the enum choices that can be traversed to find out the properties and types present in that state of the union. ((Delivers a State of the Union Address?))
In other words ... A regular plain enum (functionality that is already implemented) is just a special case of a tagged union: an empty union with no data properties connected to the state string.
What do you think!?
Ralph
Ralph Lange               Ralph.Lange@bessy.de     Tel: +49 30 6392-2117
BESSY Controls Group      www.bessy.de             Fax:      ...   -4859
Re: V4 Data Types: Request for tagged unions Andrew Johnson
RE: V4 Data Types: Request for tagged unions Jeff Hill
Prev: Re: Fundamental Types document Andrew Johnson
Next: V4 Database Access Ralph Lange
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Prev: Re: Fundamental Types document Benjamin Franksen
Next: Re: V4 Data Types: Request for tagged unions Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
