A few brief comments about dataAccess.
In the tutorial "dataViewer" is used in several places. I think you mean
propertyViewer.
I can see how almost everything in the da*.h files could be described in
Java (unsigned is one exception). Everyplace where dataAccess uses
multiple inheritence, the classes are equivalent to Java interfaces. In
fact it looks easy to create an equivalent set of Java classes and
interfaces for what appears in da*.h. Of course, this is not the
implementation but only the user interface.
I can also see how record/device support could be written in C instead
of C++ and dataAccess could still be used by iocCore supplied libraries
to transport data into and out of records. If we go with the V4 DBD idea
of struct and array, utilities like dbToStructH,etc, could generate a
header file AND code that uses dataAccess to get/put the struct fields.
We still have lots to think about in order to implement the Functional
Requirements for V4. If we decide to use dataAccess it is only part of
what is required.
Marty
- RE: dataAccess Jeff Hill
- RE: EPICS base V4: iocCore database Jeff Hill
Re: EPICS base V4 Ralph Lange
Re: EPICS base V4: iocCore database Marty Kraimer
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
