Bob Dalesio wrote:
Marty pointed out then that the use of forward links and passive records
made the load leveling a very difficult problem. Since then, I would add
that there are times that you want to have records of a slower period still
all process at the same time.
But most probably not *all* records of that slower period, only those
who belong to a certain subsystem, right?
Hmm ... let's assume that every of these user named and created scanner
threads can be configured to process its records either "synchronised en
bloc" or "balanced". In that case the desired behaviour could be
achieved by having your set of records all processed by a certain
thread, which is configured to do it "en bloc", right?
Perhaps an alternative would be to specify the base rate for the periodic
scanner.
Use PHAS to set which of the sub-periods to use to process the record
So - if the base scan period is 60 Hz, and you define a 1 second scan
record, PHAS of 30 would be at the halfway point of the 60 Hz scanning.
Another interesting idea. I would rather have the load-balancing case
being the default, though. At least I'd like the load-balancing setting
to be easy, and the grouping to be the more elaborate configuration.
To bring this back to the functional specifications - the question seems to
be:
Do we need to be able to support "load balancing"
I think that it does not buy us much - but it is nice to give the database
engineer more control.
I have seen some cases where in case of a serial-type connection
underneath a large number of IO-connected records in a slow task (e.g.
the 10 second scan taking more than 1.5 seconds to finish) was filling
up low level queues so that fast processing (going through the same
queue) was heavily affected. With almost no way to change this behaviour.
Load-balancing would make the IOC a lot more "elastic" in this regard.
Ralph
- Re: EPICS base V4: iocCore database Marty Kraimer
- Re: EPICS base V4: iocCore database Andrew Johnson
- Re: EPICS base V4: iocCore database: Booleans Benjamin Franksen
- EPICS base V4 Marty Kraimer
- Re: EPICS base V4 Andrew Johnson
- Re: EPICS base V4 Ralph Lange
- Re: EPICS base V4 Bob Dalesio
dataAccess Marty Kraimer
<2005>
<2005>
