1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: EPICS Base building for NI myRIO (arm linux)
From: inari badillo via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Mon, 23 Jan 2023 09:36:00 +0100
 Hello all,
I am trying to install EPICS base 7 on a NI myRIO 1900 (ARM CortexA9) with Linux RT.
I am installing in the host itself.
At some point of the installation, I get the following error:
"../flex/ccl.c:147:37: error: too many arguments to function 'char* readable_form()'
             fputs( readable_form( i ), file );"
I'm afraid some library is missing, but I have no clue.
Any help is very welcome.
Could you check if building with the branch from this PR works? https://github.com/epics-base/epics-base/pull/323
I'm surprised your compiler is complaining about this, though. Can you share what version and what compiler options, if any, you're using?
Could you provide more of the build output?
At minimum, the full command line when ccl.c is compiled.
I'm wondering if this ccl.c is being compiled as c++ code
('g++' vs. 'gcc').  The prototype of readable_form() is
valid, if antiquated C syntax.  However, if treated as
c++, should result in the error you report.
Thank you for your fast replies.
It was just the g++ compiler; for some reason symlink was not working.
EPICS is running on myRIO. Next step, caLAB.
Regards.
Inari Badillo Fdez.
Elektrizitate eta Elektronika saila
UPV/EHU
Prev: Re: abdf1 driver that logs with logMsg? - I know this is a real long shot Maren Purves via Tech-talk
Next: Which VMEbus CPU for EPICS7 and RTEMS? Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: EPICS Base building for NI myRIO (arm linux) Michael Davidsaver via Tech-talk
Next: EPICS Code-a-thon Collaboration Workshop - Registration Now Open Diamond Events via Tech-talk
ANJ, 23 Jan 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
