Hello Oscar
Many years ago, we happened to use the RDB archive engine
so I will give you what I remember from that time. The RDB
archive engine is a server application installed on a
separate server. Once configured, the engine will start
save samples from the configured PVs. The role of
CSS/Phoebus is that it contains the data browser tool. The
data browser tool connects to the archive engine via the
preferences and configurations you mentioned, then you can
view archived data on the data browser tool. The archive
engine is a java application consisting of two tools, the
config tool and the engine. The config tool is used to
load PV configuration into the RDB and the engine tool is
used to start the archiver itself. Unfortunately I could
not find download links for it.
Hope this helps.
Abdalla.
-----Original Message-----
<tech-talk-bounces at aps.anl.gov> On
Behalf Of Oscar Ibañez via Tech-talk
Sent: Thursday, January 12, 2023 11:03 AM
To:
tech-talk at aps.anl.gov
Subject: EPICS, PostgreSQL, Archive Engine: doubts about
how to use them
I am trying to set up a PostgreSQL RDMS to work together
with EPICS to save some PV values. However, I am having
doubts about how to do it, since the process is not clear
to me.
First of all, I installed EPICS and I downloaded Phoebus.
Both are running with no problem. In addition, I installed
PostgreSQL. It seems to work fine. Then, I tried to learn
how to connect EPICS and PostgreSQL, and I ended up
reading Phoebus documentation about the RDB Archive
Engine, and that was the point when I did no understand
what I was doing.
https://gcc02.safelinks.protection.outlook.com/?url="">
The document says that I need to download the archive
engine from:
But I can't find any archive engine in that place.
In addition, I am confused about the rol of Phoebus in
this problem. Why do I need to set up any preference in
the Phoebus configuration to use the Archive Engine?
Phoebus is just a software to create and to display
graphical screen to monitor/check the control system. If I
run the Archive Engine, that software will save PV values
in the PostgreSQL tables that I want. So, I don't
understand the relationship between Phoebus and the
Archive Engine, since the documentation is in the CSS web.
Any help would be useful.
Regards.
Óscar
