Another example, Automation1 driver in order to calculate the position, it reads the resolution from the controller it does not read motorResolution_ nor motorRecResolution_.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of
Abdalla Ahmad via Tech-talk
Sent: Monday, January 9, 2023 1:43 PM
To: tech-talk at aps.anl.gov
Subject: Understanding Asyn-based motor controller driver
Hi
I am trying to understand how a motor controller driver works and how the asynMotorController and Axis classes map to the EPICS motor record. For example, I am investigating this driver from ACS motion
https://github.com/epics-motor/motorAcsMotion to see if it supports some functions from the motor record that are required by our data acquisition system. Here are my questions:
1.
motor jogging: since the class does not implement the “::moveVelocity” function, does this mean that the driver does not support jogging at all? Or it does at the low-level motor record interface?
2.
VELO and ACCL fields: The class uses different variables to hold acceleration and velocity information other than the base class’s variables “motorVelocity_” and “motorAccel_”. Does this mean that VELO and ACCL
fields are useless? Same thing goes for the OFF field.
In other words, if a motor driver is based on the motor record, does this guarantee that all fields are functional and working with the controller? How to verify if a certain function not implemented in the asyn classes but working and
implemented somewhere else?
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME (Synchrotron-light for Experimental Science and Applications in the Middle East)
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
abdalla.ahmad at sesame.org.jo
www.sesame.org.jo
