1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Scan rate '.01 second' not achievable
From: Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
To: "Barrett (US), Patrick E" <patrick.e.barrett at boeing.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 6 Jan 2023 14:48:26 +0000
On 06/01/2023 11:18, Barrett (US), Patrick E via Tech-talk wrote:
Hello,
We have added a scan rate of “.01 second” to our scan menu to have records processed at 100 Hz (10 ms), but we are getting the “Scan rate is not achievable” message.  Is this due to the clock rate not being able to match 10ms? What does the system set the scan rate to when it receives a message like this?  We are running on Linux Oracle 8 OS.  I would think a 10ms rate would be achievable.
Thank you,
Patrick Barrett
Stage Controller Software Engineer
The Boeing Company
Hi! Apologies for the double email, Patrick, I had initially responded only to you instead of to the list.
What version of EPICS are you using? I'm looking at EPICS 7, and from what I can see, it uses the following heuristic:
        number = ppsl->period / quantum;
        if ((ppsl->period < 2 * quantum) ||
            (number / floor(number) > 1.1)) {
            errlogPrintf("initPeriodic: Scan rate '%s' is not achievable.\n",
                choice);
where quantum is determined by epicsThreadSleepQuantum().
On Linux, that function uses essentially '1.0 / sysconf ( _SC_CLK_TCK )'. The sysconf value is usually 100 (Hz), and it would explain why EPICS thinks it won't achieve the desired scan rate. I don't think a modern kernel will actually be limited by its tick rate, so I don't know how accurate that heuristic is.
Either way, the 'period' value isn't touched after this verification, so I think the IOC will still attempt to use it. You could try running a simple counter in your SCAN and checking with camonitor if the 100Hz rate is actually achieved.
I think scanppl() might have trouble detecting overruns with a period of 0.01, though:
        if (period > 0.0 &&
            (fabs(period - ppsl->period) > 0.05))
            continue;
By the way, epicsThreadSleepQuantum() can return 0.0 if the sysconf errors out, which I believe would result in a SIGFPE in initPeriodic() when dividing by quantum.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
RE: Scan rate '.01 second' not achievable Barrett (US), Patrick E via Tech-talk
Re: Scan rate '.01 second' not achievable Ricardo Cardenes via Tech-talk
Re: Scan rate '.01 second' not achievable Michael Davidsaver via Tech-talk
Prev: Scan rate '.01 second' not achievable Barrett (US), Patrick E via Tech-talk
Next: RE: Scan rate '.01 second' not achievable Barrett (US), Patrick E via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
ANJ, 08 Jan 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
