1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Subject: AW: Errors during installation of StreamDevice - V2
From: "Zimoch Dirk \(PSI\) via Tech-talk" <tech-talk at aps.anl.gov>
To: Ewen Mallegol <emallegol at sigmaphi.fr>
Cc: "ewen.mallegol1 at gmail.com" <ewen.mallegol1 at gmail.com>, EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Tue, 18 Jan 2022 13:52:35 +0000
You need to build asyn first before building StreamDevice. (And point to the correct path in your RELEASE file.)
Dirk
Von: Tech-talk <tech-talk-bounces at aps.anl.gov> Im Auftrag von Ewen Mallegol via Tech-talk
Gesendet: Dienstag, 18. Januar 2022 14:45
An: tech-talk at aps.anl.gov
Cc: ewen.mallegol1 at gmail.com
Betreff: TR: Errors during installation of StreamDevice - V2
Hello everyone,
I'm new to EPICS and i want to install StreamDevice but i encountered multiple errors.
I'm working on the iso files(RedHat) from the 2019 USPAS training on virtualbox.
At the architectural level I have to epics folder one from the epics-train and one just base-7.0.
When i download and make StreamDevice i have errors about "no such files or directory" so
I analyzed the other and copy/paste the missing files.
Now my last fatal error is about the library libasyn.a and particularly libstream.so ( you have the terminal window below).
[training@training StreamDevice]$ make
If you are not using the PSI build environment, GNUmakefile can be removed.
make -C ./configure install
make[1]: Entering directory `/home/training/base-7.0/tools/support/StreamDevice/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory `/home/training/base-7.0/tools/support/StreamDevice/configure/O.linux-x86_64'
perl -CSD /home/training/base-7.0/src/tools/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/training/base-7.0/tools/support/StreamDevice/configure/O.linux-x86_64'
make[1]: Leaving directory `/home/training/base-7.0/tools/support/StreamDevice/configure'
make -C ./src install
make[1]: Entering directory `/home/training/base-7.0/tools/support/StreamDevice/src'
make[2]: Entering directory `/home/training/base-7.0/tools/support/StreamDevice/src/O.linux-x86_64'
make[2]: *** No rule to make target `../../lib/linux-x86_64/libasyn.a', needed by `libstream.so'.  Stop.
make[2]: Leaving directory `/home/training/base-7.0/tools/support/StreamDevice/src/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/home/training/base-7.0/tools/support/StreamDevice/src'
make: *** [src.install] Error 2
Thanks in advance for helping me
Ewen
Errors during installation of StreamDevice Ewen Mallegol via Tech-talk
TR: Errors during installation of StreamDevice - V2 Ewen Mallegol via Tech-talk
Prev: Re: Errors during installation of StreamDevice - V2 Simon Rose via Tech-talk
Next: Installation error makeMakefile.pl & bin folder missing Ewen Mallegol via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
