Hi Yong,
Thank you for your reply. That is what i figured but was not seeing it
yesterday. It looks like I had a instance of the script running from
before which confused me. It works as you described.
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: dcosic at irb.hr | www.irb.hr
Dana 07.01.2022 00:14, Hu, Yong via Tech-talk je napisao(la):
Hi Donny,
As long as you use “sudo manage-iocs start myIOC” to start your
IOC and “sudo manage-iocs stop myIOC” to stop your IOC, the Python
process "python your-python-file.py" should be automatically
terminated when the IOC is stopped.
Try this before and after you type “sudo manage-iocs stop myIOC”:
ps -ef | grep your-python-file.py
You will see the process come and then go away.
Cheers,
Yong
FROM: Donny Domagoj Cosic <Donny.Domagoj.Cosic at irb.hr>
DATE: Thursday, January 6, 2022 at 5:40 PM
TO: Hu, Yong <yhu at bnl.gov>
CC: GAGET Alexis <alexis.gaget at cea.fr>, tech-talk at aps.anl.gov
<tech-talk at aps.anl.gov>
SUBJECT: Re: Start IOC automatically at boot
I added - system "python your-python-file.py &" to my st.cmd file and
when the ioc starts, the python scripts start! Thank you for the
suggestion.
However when I stop the ioc, the python scripts remain running in the
background. How can I get the python scripts to stop when the ioc is
stopped?
Donny Domagoj Cosic
https://urldefense.com/v3/__http://www.irb.hr__;!!P4SdNyxKAPE!WeEYOl_03uqMBGrFKBjASsDC4I7VlxQzQpy_fCSLKoUG-QZEsW1-JZjNVmnB$
Dana 06.01.2022 18:35, Hu, Yong je napisao(la):
> Another way automatically start the python script with the ioc,
simply
> add this kind of line at the end of your IOC’s st.cmd:
> However, you need include “system.dbd” in your IOC application.
In
> your application’s src/Makefile, add this kind of line:
> yourIOCApplicationName_DBD += system.dbd
> FROM: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of GAGET
> Alexis via Tech-talk <tech-talk at aps.anl.gov>
> DATE: Thursday, January 6, 2022 at 12:11 PM
> TO: Donny Domagoj Cosic <Donny.Domagoj.Cosic at irb.hr>,
> tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
> SUBJECT: RE: Start IOC automatically at boot
> Hi,
> "Is there a way to automatically start the python script with the
> ioc?"
> -> You can simply use procServ as well to execute your python
script
> DE : Tech-talk <tech-talk-bounces at aps.anl.gov> de la part de Donny
> Domagoj Cosic via Tech-talk <tech-talk at aps.anl.gov>
> ENVOYÉ : mercredi 5 janvier 2022 21:30:07
> À : Ralph Lange via Tech-talk
> OBJET : Start IOC automatically at boot
> Happy new year!
> I am trying to install systemd-softioc (procServ) as outlines here
> https://github.com/NSLS-II/systemd-softioc [1] [1]. I followed the
> instructions
> and successfully installed it on my Raspberry Pi. I installed the
IOC
> and can manually start the softioc, however I am not able to start
> the
> IOC using manage-iocs. I get the following output:
> softioc@raspberrypi:/epics/iocs/testIOC2$ sudo manage-iocs start
> testIOC2
> Starting the IOC 'testIOC2' ...
> Failed to start the IOC 'testIOC2'; type 'sudo journalctl -xe' for
> details.
> Below is my config file and output from the journalctl
> Config
> NAME=testIOC2
> PORT=4053
> HOST=raspberrypi
> USER=softioc
> CHDIR="/epics/iocs/testIOC2/iocBoot/ioctestIOC2"
> EXEC="$CHDIR/st.cmd"
> Output from journalctl
> Jan 05 21:11:29 raspberrypi sudo[13371]: softioc : TTY=pts/0 ;
> PWD=/epics/iocs/testIOC2 ; USER=root ; COMMAND=/usr/bin/manage-iocs
> install testIOC2
> Jan 05 21:11:29 raspberrypi sudo[13371]: pam_unix(sudo:session):
> session
> opened for user root by (uid=0)
> session
> closed for user root
> Jan 05 21:11:43 raspberrypi sudo[13423]: softioc : TTY=pts/0 ;
> start testIOC2
> Jan 05 21:11:43 raspberrypi sudo[13423]: pam_unix(sudo:session):
> session
> Jan 05 21:11:43 raspberrypi systemd[1]: Reloading.
> Jan 05 21:11:43 raspberrypi systemd[1]: [email protected]:
> Current command vanished from the unit file, execution of the
command
> list won't be resume
> Jan 05 21:11:43 raspberrypi systemd[1]: plexmediaserver.service:
> Current
> command vanished from the unit file, execution of the command list
> won't
> be resumed.
> Jan 05 21:11:44 raspberrypi systemd[1]: Condition check resulted in
> IOC
> testIOC2 via procServ being skipped.
> -- Subject: A start job for unit softioc-testIOC2.service has
> finished
> successfully
> -- Defined-By: systemd
> -- Support:
https://urldefense.com/v3/__https://www.debian.org/support__;!!P4SdNyxKAPE!WeEYOl_03uqMBGrFKBjASsDC4I7VlxQzQpy_fCSLKoUG-QZEsW1-JWSxDXye$
[2] [2]
> -- A start job for unit softioc-testIOC2.service has finished
> successfully.
> -- The job identifier is 1803.
> Jan 05 21:11:45 raspberrypi sudo[13423]: pam_unix(sudo:session):
> session
> Jan 05 21:11:54 raspberrypi sudo[13487]: softioc : TTY=pts/0 ;
> PWD=/epics/iocs/testIOC2 ; USER=root ; COMMAND=/usr/bin/journalctl
> -xe
> Jan 05 21:11:54 raspberrypi sudo[13487]: pam_unix(sudo:session):
> session
> The softioc testIOC2 contains a few records which get updated from
a
> python script. Which brings me to my next questions. Is there a way
> to
> automatically start the python script with the ioc?
> Thank you very much for your help,
> Regards
> Donny Domagoj Cosic
[3] [3]
> Links:
> [1] https://github.com/NSLS-II/systemd-softioc [1]
> [2]
https://urldefense.com/v3/__https:/www.debian.org/support__;!!P4SdNyxKAPE!XScIVOM_CZDyHbp9c76gj4WzN_hFVrfqEqfAzjKK-hfgXnNgknPHzlsNS57f$
[4]
> [3]
https://urldefense.com/v3/__http:/www.irb.hr__;!!P4SdNyxKAPE!XScIVOM_CZDyHbp9c76gj4WzN_hFVrfqEqfAzjKK-hfgXnNgknPHznuurVW7$
[5]
Links:
[2]
https://urldefense.com/v3/__https:/www.debian.org/support__;!!P4SdNyxKAPE!WeEYOl_03uqMBGrFKBjASsDC4I7VlxQzQpy_fCSLKoUG-QZEsW1-JWSxDXye$
[3]
https://urldefense.com/v3/__http:/www.irb.hr__;!!P4SdNyxKAPE!WeEYOl_03uqMBGrFKBjASsDC4I7VlxQzQpy_fCSLKoUG-QZEsW1-JZjNVmnB$
[4]
[5]
- Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
- RE: Start IOC automatically at boot GAGET Alexis via Tech-talk
- Re: Start IOC automatically at boot Hu, Yong via Tech-talk
- Re: Start IOC automatically at boot Donny Domagoj Cosic via Tech-talk
Re: motor record startup Siddons, David via Tech-talk
<2022>
Re: ADVimba memory leak ? John Dobbins via Tech-talk
<2022>
