Hi, Xiaoqiang. Where you not able to verify this problem? This should
be independent from the other issue I reported.
I still see the same problem with the head of master (1f0a509). I'm
using EPICS 3.15.5.
jamie.
On Wed, Dec 27 2017, Jameson Graef Rollins <[email protected]> wrote:
> Hi, Xiaoqiang et. al. I'm seeing some behavior in pcaspy 0.7.0 that I'm
> not understanding, and I'm hoping you can help me figure out what's
> going on.
> I have a trivial test pcaspy IOC (code attached) serving a single
> channel "TEST:A". After starting the IOC I run camonitor on the
> channel:
> $ camonitor TEST:A
> TEST:A 2017-12-27 19:15:42.991145 0
> If I then put the *same* initial value into the channel...
> $ caput TEST:A 0
> Old : TEST:A 0
> New : TEST:A 0
> ...I see an update:
> guard-test> camonitor TEST:A
> TEST:A 2017-12-27 19:15:50.661466 0
> Additional puts with the same value show no more spurious updates. So
> this only happens immediately after initialization.
> This is contrary to the behavior that I now expect, whereby there would
> never be external updates if the value was not changing. Can you help
> me understand what's going on?
> Basically I'm looking for the best way to get consistent behavior out of
> the pcaspy driver, either where puts always show updates even if the
> value is the same, or that puts of the current value do not ever show
> updates. How can I achieve this?
> Thanks in advance for any help.
> jamie.
> #!/usr/bin/env python
> import sys
> import pcaspy
> prefix = 'TEST:'
> pvdb = {
> 'A': {
> 'prec': 0
> class DummyDriver(pcaspy.Driver):
> pass
> server = pcaspy.SimpleServer()
> server.createPV(prefix, pvdb)
> driver = DummyDriver()
> for k in pvdb:
> driver.setParamStatus(k, pcaspy.Severity.NO_ALARM, pcaspy.Severity.NO_ALARM)
> driver.updatePVs()
> while True:
> server.process(0.1)
signature.asc
Description: PGP signature
- same value updates after initialization in pcaspy 0.7.0 Jameson Graef Rollins
Re: usage of updatePVs in pcaspy Wang Xiaoqiang (PSI)
Re: usage of updatePVs in pcaspy Jameson Graef Rollins
<2017>
Re: same value updates after initialization in pcaspy 0.7.0 Jameson Graef Rollins
<2017>
