Hello,
I am writing an asynPortDriver port on top of the modbus EPICS module
and I would like to read the initial values of the modbus registers for
writing functions.
I am currently working with modbus 2-10-1 and asyn4-30 and I am using
the absolute addressing. I noticed that when calling readInt32Array on
the modbus port using modbus function 16, the module always performs a
TCP query but does not return the values, because it enters the
following lines of code:
drvModbusAsyn.c line 1276:
case MODBUS_WRITE_SINGLE_REGISTER:
case MODBUS_WRITE_MULTIPLE_REGISTERS:
case MODBUS_WRITE_MULTIPLE_REGISTERS_F23:
printf("write multiple registers\n");
if (!pPlc->readOnceDone) return asynError;
and readOnceDone is false. This way I can never read the initial values
of the registers. Is this a know behavior or is it an error?
In the readInt32 function (drvModbusAsyn.c line 878) the variable
readOnceDone is set to 1 after the call to doModbusIO. Is there a reason
for not being the same on the readInt32Array function?
Furthermore, would it be a good idea to avoid performing modbusIO more
than once in absolute addressing mode when using a write modbus function
(eg: 16)? This would keep the behavior consistent with the rest of the
module.
I also noticed that on the rest of the module, when trying to read on a
"output" port (meaning that a modbus write function code is in use) the
module always return the value it read at startup, on the first (and
only) reading. Is there a reason why the values written to those
registers are not cached and the last written value is returned instead
of the value the register had on the first reading? I mean somenthing like:
1 - the registers are read (doModbusIO) and their value is saved to a cache
2 - the user writes to some of those registers
3 - the user tries to read those same registers and the modbus module
returns the last cached value for each register
Thank you,
Davide
Davide Marcato
INFN - Laboratori Nazionali di Legnaro
Viale dell'Universita', 2
35020 LEGNARO (PD) - ITALY
Phone: +39 0498068439
Re: Event triggers for plusers not detected (mrf-timing system) Bjorklund, Eric A
Channel Archiver compilation error Wang, Lin
<2017>
Re: Save MCA record data Mark Rivers
<2017>
